I have been looking for something to take off cured powder coat. I wanted to stay away from harsh chemicals, which seemed to be hard to do. I finally gave in to the chemical route and tried the Crystal Drano someone on here had suggested. It worked ok but I still had to blast some of it. So I continued my search. I got various suggestions from this chat forum that I was going to try, like Zip Strip and Tal Strip. When I went to Home Depot to try and find Zip Strip I ran into Citristrip gel. I decided to give it a try since it is biodegradable and advertised safe for indoor use / low odor. Well let me tell everyone on here, this stuff works!!! I brushed some onto a coated wrench and 5min later it brushed off with a stiff bristled brush. I left some on longer, it started to liquefy the powder and run down the side of the wrench. It really doesn’t have a bad odor and mainly smells like oranges. 32oz was about $11.50 but since it is a gel it goes a long way and stays where you put it. I would highly recommend this stuff.
Art |
I've looked at that stuff about a hundred times but never really considered using it. I have some display pieces that I'm going to reshoot this week, so maybe I'll try it. Thanks for the tip.
I picked some up the other day , worked pretty good on painted parts..
But tried to Stripp a factory powder coated 1999 mustang cobra wheel, and it didnt even touch the surface.. that was multiple coats over a 24 hour period..
http://www.HP-Powdercoatings.com |
| I found sand blasting aluminum prior to powder coating is a big no-no. | mtumbleson | Powder Coating Questions | 59 | 04-07-2008 07:37 PM |
| Fs: Turnkey Powder Coating And Ceramic Coating Business!!!! | Mcurtis7 | Used Items For Sale | 0 | 10-02-2005 02:18 PM |
| Removal of unknown coating on aluminum | rclint | Metal Polishing Questions | 6 | 08-25-2005 12:04 AM |
| Non-paint powder coating | dshepherd | Powder Coating Questions | 6 | 01-26-2004 11:49 AM |
| Does a coating exist that can be bent slightly? | Augest | Powder Coating Questions | 1 | 09-22-2003 01:34 PM |
