Old 11-03-2006, 07:30 AM
autoshopowner's Avatar
autoshopowner is on a distinguished road
Default 30 to 50 KV Gun Adjustments?
When I first start out, with the gun, very little powder comes out, if I shake the gun, way too much comes out (it is consistent once the heavy output starts)??
I have a mini regulator on the gun set to 10 PSI (also the moisture separator).
Powder does not seem to stick, well, to the object being coated. The ground clip is attached directly to the object and the contact is clean.
Help.
Old 11-03-2006, 06:19 PM
Default Re: 30 to 50 KV Gun Adjustments?
You might need a little more pressure? Try increasing to 12-15PSI, see how it does. Also, the powder should be shook for a while before putting into the gun cup. It has a tendancy to 'pack' and won't fluidize correctly. Other than that, hold gun pretty much level. buildup inside the gun is inevitable because it's a large discharge tube and low pressure. Hollding the gun level will help avoid accidents. As far as the voltaje and not sticking, I am not sure. Mine sticks like crazy even ay 30KV setting. Are you sure it's working? Do you get an arc when you touch the electrode of the gun to the ground clip?
Dan Pesonen
Forest Grove, BC Canada
Personal motto:
Gun cleaning gcastor Powder Coating Questions 12 10-24-2006 05:06 PM
want educated on caswells new gun skooterbum Powder Coating Questions 7 09-14-2006 08:52 PM
Looking to purchase pro type gun from caswell have questions chicagorich Powder Coating Questions 10 03-23-2006 01:05 AM
Professional gun? mtnbiker Powder Coating Questions 10 03-14-2006 09:25 PM
Hey another question! Powder Gun acting weird cruizer Powder Coating Questions 3 10-06-2005 05:11 PM
