Go Back   Caswell Inc. Metal Finishing Forums > Powder Coating Questions
Connect with Facebook
Closed Thread
Old 11-07-2006, 09:56 PM
autoshopowner's Avatar
autoshopowner is on a distinguished road
Default Help, I'm doing spmething wrong
I have tried everthing I can think of. I can not get a consistance "cloud" of powder out of the gun. It is fine for a while but the barrel seems to fill up. When I point the gun down with no air a sugnifficant amount of power falls out of the gun. I can not seem to adjust the amount of air to powder ratio??
Old 11-07-2006, 10:51 PM
Default Re: Help, I'm doing spmething wrong
1 inch to 1-1 /2 inch of powder in the cup
20 PSI input so that when you pull the trigger it stays at around 15
and play around with the screw under the barrel
this are the setting for my hobby gun.
hope it helps
Old 11-07-2006, 11:18 PM
I have the pressure at the compressor set at 30 PSI. I have a mini regulator at the gun set at 20 PSI I have used setings on the adjustment at the inlet from almost all the way in to almost falling out. The screw under the barrle seems to make no difference if screwed al the way in to almost all the way out. I have fluffed the powder (shaken the cup before installing on the gun). There is a dehumidifier running. Powder is new. ??
Am I expecting to much for this gun? I have done a fair amount of spray painting. I know how to allpy an even coat, I just cannot get consistance out of the gun.
Old 11-08-2006, 08:13 PM
chromeitout's Avatar
chromeitout is an unknown quantity at this point
It may or may not be the case, but as stated above I find that the powder level in the gun makes more difference than anything else for me. I try to keep it between 1 and 1 1/2", too. Too little in the gun it won't come out unless you shake it, too much and it sporatically coughs big amounts of powder.
Closed Thread
What did I do wrong this time? oldgoat69 Powder Coating Questions 2 08-15-2006 05:18 PM
Can you figure out what I did wrong? cruizer Powder Coating Questions 11 07-17-2006 04:34 PM
Cartridge rolls - description wrong? mpierich Caswell Please Sell This... 1 06-15-2005 12:52 AM
Ok,what am I doing wrong mach1man Metal Polishing Questions 1 08-18-2004 08:31 PM
What am I doing wrong here PC101 Powder Coating Questions 3 06-29-2003 11:14 PM
