Thanks |
The surface is somewhat rough simalar to manifolds I didn't know if this is something I can smooth out with blasting or if I need to grind which would suck due to hard to reach areas. I will be working on it today so I will post picure of it if I can figure out how.
ok I tryed sand blasting on the primary and I'm not sure if it me or the sand blaster not working right, but I used the airplane paint remover and then I angle grinded and sanded the part that I want to look smooth and shine..
I am having a hard time uploading the picture. the pic is to big in size and I don't know how to change it. |
| Something for you die hard polishers out there to chew on | thesound | Metal Polishing Questions | 15 | 12-03-2007 01:16 PM |
| Black dots in the cast aluminum | dekebell | Powder Coating Questions | 0 | 04-11-2006 10:23 PM |
| Problems w/ cast aluminum | sthomag | Metal Polishing Questions | 2 | 02-03-2006 02:41 AM |
| Cast Aluminum | scocklin | Anodizing Questions | 5 | 12-04-2004 12:38 AM |
| Cast iron prep | ewmorritt | Metal Polishing Questions | 1 | 05-28-2003 01:31 AM |
