I just finished a PC cabinet, the powder coating area is 4'x3'x4'. I've never used a cabinet to powder coat in so I'm not sure what to expect in regard to the powder floating around.
I'm thinking I should put in a down draft (or one out the back would be easier), what do you all suggest? Does it even matter? |
OUt the back is better IMO Keeps the loose cloud away from you. BUt, you need to becarefull what kind of fan you use. SHopvac styles are NO-NO They can cause the powder to explode. You don't need one, but you will find powder floats EVERYWHERE in your shop. Only wat to keep it clean is with a fan of some type
Dan Pesonen Bandit Powder Coat <<From Powder to Perfection>> Forest Grove, BC Canada Personal motto: "If it ain't broke, modify somethin till it is" |
My first booth was a down draft. I used a piece of rectangular duct...cut a hole in the floor of the booth, and the top of the duct, with a furnace filter over the hole. At the end of the duct I used an adapter and went from the rectangular end of the duct to an 8" round duct with a 500 cfm fan in the duct. From there I used a flexible tube to send it out of the shop. Worked great until I got too busy and it couldn't keep up with the demand.
| sand blasting cabinet...relocated to tips n tricks section | duke | Powder Coating Questions | 15 | 12-30-2007 11:28 AM |
| Incandesent lighing in blast cabinet | ottoplex | Powder Coating Questions | 1 | 09-10-2006 10:05 PM |
| modified cheap blasting cabinet | chromeitout | Powder Coating Questions | 6 | 06-12-2006 10:30 PM |
| Converting a syphon media cabinet to a pressure cabinet? | trsick | Powder Coating Questions | 3 | 03-22-2005 08:41 PM |
| What material for cabinet building | BryanD | Electroplating Questions | 1 | 10-18-2003 01:04 PM |
