Go Back   Caswell Inc. Metal Finishing Forums > Powder Coating Questions
Connect with Facebook
Closed Thread
Old 11-25-2006, 02:31 PM
precise is on a distinguished road
Default powder coating Rims
Has anyone desgin a bracket for powder coating car rims, I need some kind of a idea too where I can coat a rim and take it straight too the oven
Old 11-25-2006, 07:20 PM
callmej75 is on a distinguished road
Send a message via Yahoo to callmej75
Default Re: powder coating Rims
I was initially going to get a piece of 1x1 steel tubing and make it to hang off of my 1x1 square rack with a piece of 1x1 steel welded to it sticking out to hold the rim suspended.
Old 11-25-2006, 08:29 PM
tnc tnc is offline
tnc is on a distinguished road
I used to use steel braided line and now I use a small chain which I just wrap around the rim and attach the chain bach to itself. Put a hook through the other end of the chain and hang the rim up.
Old 11-26-2006, 02:23 PM
myillwillinc's Avatar
myillwillinc
i have a 6in bolt and washers( the ones with a eye hole in one end) that i put thru the air valve hole. then i can hang it on a 4ft rack piece in my spray booth and carry the whole thing to the oven to hang in there with out touching the wheel. i have used this method a number of times and it works great. hook the eye to a swivel hook like they sell here and u can spin the wheel effortlessly to shoot all the way around it.
Old 11-28-2006, 11:50 PM
Do you coat the area where the chain hangs ?
How bad of a mark does that, Leave on the rim. ?
Old 11-30-2006, 02:37 AM
myillwillinc
if u get a nut that fits inside the recess of the hole the air stem hides where the powder didn't cover from the nut.
http://www.illwillinc.com/
PC'ing -> trods
Closed Thread
*** WE ARE GIVING AWAY FREE POWDER COATING *** mcaswell Powder Coating Questions 205 09-21-2009 10:55 AM
Fs: Turnkey Powder Coating And Ceramic Coating Business!!!! Mcurtis7 Used Items For Sale 1 02-19-2009 02:39 PM
I found sand blasting aluminum prior to powder coating is a big no-no. mtumbleson Powder Coating Questions 59 04-07-2008 08:37 PM
powder coating over powder coat? corybarta Powder Coating Questions 6 08-21-2006 09:15 AM
Non-paint powder coating dshepherd Powder Coating Questions 6 01-26-2004 12:49 PM
