FREE POWDER COATING SYSTEM
HV Powder Coating System
Buy Now
Old 11-30-2006, 07:58 PM
krymis is on a distinguished road
Default black chrome problems
I have a sportster air cleaner cover I am coating in black chrome with a super chrome undercoat. I spray out the undercoat and it looks great. then i spray out the black chrome and the color is great but there are spots in the black chrome. They look like the powder just pulled away from the areas. I coated the parts twice with the same results. I have cleaned the part with purple power and water and then cleaned with acetone. The spray scheduel went chrome base sprayed, part at room temp, cooked at 400 for 7 min, air cooled to 154, sprayed black chrome, goes on fine all coated, cooked at 410 for 15 minutes. pulled out and there are the spots. pics attached.....
Old 11-30-2006, 10:01 PM
Default Re: black chrome problems
what gun are you ussing
is this happening with this color only ?
same thing happend to me when i first got my nordson
I had a bad resistor and a bad ground point on my booth.
Old 11-30-2006, 10:12 PM
chromeitout's Avatar
chromeitout is an unknown quantity at this point
Looks like fisheyes (contaminents such as oil), but it's hard to tell from the pics. If the chrome didn't do it then maybe something is getting onto the surface between coats. Moisture in your lines will cause this too, and candies will do it worse than solids. Try being extra careful keeping the surface clean and a moisture filter right at your gun. If you have one already change it and try that.
Old 12-03-2006, 01:35 PM
DocMartin is on a distinguished road
Have you tried spraying the black chrome separately?
Like chromeitout said, from the pictures the defects do look like fisheyes. Another contamination source might be from traces of incompatible powder in your booth, or in the powder itself.
Back ionization or poor grounding, like Jtagger19 mentioned, could also cause similar defects, but then your bottom layer would also show the spots.
Problems with Super Chrome Helf8704 Powder Coating Questions 6 03-11-2006 08:13 PM
Black Chrome WAORacing Powder Coating Questions 7 10-11-2005 11:40 PM
Black chrome keith_a_bond Electroplating Questions 3 04-30-2004 12:06 AM
Chromed Plastic to Black Chrome Ultrasparq Electroplating Questions 1 02-17-2004 11:16 PM
shadow chrome / black chrome MildSeven Metal Polishing Questions 1 12-06-2002 09:33 AM
