FREE POWDER COATING SYSTEM
HV Powder Coating System
Buy Now
Old 12-24-2006, 09:39 AM
coleman5 is on a distinguished road
Default fish eye any way around it ?
i have been doing a lot of mc parts fork tubs side covers thanks like that some parts come out smooth some have powder fish eye not fish eye from oil or something on the part. do you know what i mean can i bake the part at like 200 for say 30 min to let powder flow better or is their something i am missing ? i wet sand the fish eye out and buff it would be nice not too have to.
thanks for your input.
Old 12-24-2006, 12:21 PM
Default Re: fish eye any way around it ?
200F?? That's way to cold. need 400*F
Dan Pesonen
Forest Grove, BC Canada
Personal motto:
Old 12-24-2006, 02:37 PM
sswee's Avatar
Moderator
Try cleaning, de-gassing and check for any contaminants coming out of the material. I de-gas 25 to 50 degrees above cure temp for about 1/2 hour. Longer if I see oils coming out of the part. Let cool, re-clean and de-gas again.
SS
Old 12-24-2006, 07:26 PM
no no its not from contamination its normal fish eye with powder you cant tell me you dont have it. its the flow out. if you let it flow out longer its smother
but its still thear.
Old 12-24-2006, 09:29 PM
sswee's Avatar
Moderator
What you are calling fish eye is orange peel. Fish eye is caused by contamination and orange peel is the coating not flowing out. The way I deal with it is to dwell the temp that the powder starts to melt and flow for a short period of time. At times you may need to increase the coating thickness.
SS
Old 12-24-2006, 09:43 PM
thank you thats it.
sorry for the fish eye
i have tried letting the part cook at about 280/ for 15min then go up to 400 and let cook for 20min helped a little but still had some orange peal i was wondering if thear is a way to get rid of all of it ?
still new about 8 months now.
thanks for your help
and again sorry for mis comunicating my trouble
Old 12-24-2006, 11:06 PM
sswee's Avatar
Moderator
You might try holding at 300* to 325* and going with a thicker coat.
SS
  #8 (permalink)
Old 12-25-2006, 09:12 AM
mikekozura's Avatar
mikekozura is on a distinguished road
Well for what it's worth I'll tell you how I do it. Bead blast outside to remove clear coat. Spray inside real good with choke cleaner wipe down with acetone rinse with HOT water I got the water so hot by the time I take them over to hang there almost dry. Run them thru a cure cycle without
powder (out gas). Let cool to about 150* (the old 150* rule) start to coat, the powder starts to melt and I keep laying it on until it stops melting. Make sure the whole thing is covered with unmelted powder. Set timmer for 20 minutes after part reaches 385* to 400* and wala smoth as a baby's butt.
  #9 (permalink)
Old 12-25-2006, 11:25 AM
sswee's Avatar
Moderator
I use the same method Mike just explained and had great results.
SS
  #10 (permalink)
Old 12-25-2006, 03:14 PM
thanks ill try that on the next set
what did you use for the end of the fork tubs ?
do you have special plugs that size
thanks guys
Need some help making RED fish hooks nitro901 Other Metal Finishing Questions 2 03-27-2008 02:11 AM
Helpful Tip : FISH EYES OR WHATEVER customandsound Powder Coating Questions 9 02-07-2008 11:16 PM
need eye glasses plated mat nickel if poss kennyrayandersen Services Offered/Wanted 2 10-31-2006 03:32 PM
Fish eye? Asher Powder Coating Questions 3 05-21-2003 10:12 AM
