Okay, simple questiong here. I already own an air compressor. I would like to purchase the small powder coat gun kit. Is this all I need to do a couple of small jobs?
Do I need a special oven or can I use the oven in my house? Do I need a booth for such small jobs or is the booth necessary any time using this process? Is sandblasting the old paint from certain surfaces recommended before powder coating, or is simple sanding, prepping all that is needed? Any help would be appreciated as this is a new hobby I'm very interested in. Thanks, Tom Aliff www.mbhackers.com |
Do not under any circumstances use the oven in your home for powder coating. Find an old one used and place it in your garage. Sandblasting the old paint off prior to powder coating works very well and gives the powder a good surface to adhere to.If you have a compressor already and find an oven then yes the kit is all you need. Plus ordering the color powder you wish to use. Yes it is simple just requires a little trial and error to develope techniques that get you the results you are after.
They have a basic powder coating oven around $400.00.
The cooking area dimensions are 18"x18"x18" and it connects to a regular 110V outlet. I ordered one the other day to do small parts, so I'll let you know how it goes once I get it. Joe |
Nothing personal, but why would anyone pay $400 for an oven? Am I missing something?
" -------------------------------------------------------------------------------- They have a basic powder coating oven around $400.00. The cooking area dimensions are 18"x18"x18" and it connects to a regular 110V outlet. I ordered one the other day to do small parts, so I'll let you know how it goes once I get it. " ------------------------------------------------------------------------------------ Isn't that rather small? Might be great if you need to be portable, but other than that a waist of money! Buy an old electric stove with working oven, garage sale, auction, etc... $35! Maybe more or less, but close. Should be even cheaper like haul away for free if the top burners don't work! 220 is not hard to hook up if you know how to wire anything, and if not get an electrician for the $350 your saving!! If you have a decent sized air compresser it is probably 220v anyway, so you just need to connect an extra outlet for the stove. In anycase that's all you need, a cheap electric stove, air compresser, spray kit, and colors. Then of course what ever your working the metal with like taking off paint pulling dents, polishing out castings etc... The main thing is electric, as I have been told the gas produced from the baked coating is flamable, so you cannot use a gas oven!! Chromo |
I have been using the electric oven route and I didn't have the correct voltage to get it over 350. Once it got to 350 it was an 1 1/2 hours later. Allot of the newer homes and office/warehouses don't run the 220V that you need to run an electric oven. This unit is small and compact and it runs off of 110V. This oven is about the same inner dimensions as the electric stove I'm using now and it takes 10 minutes to heat up to 360 degrees F. It saves time when doing a large batch. Plus when compared to the smallest industrial model it's dirt cheap.
Also good luck trying to find a good used electric oven for $35... The cheapest I found was $125 and there is no guarantee it's going to work if not burn down your house in the process. electrician for the $350? I like to have this guys number... It was going to run us almost $800 for an electrican to run 220V into the house and that was the cheapest out of the 7 companies that we talked too. golferdude: Since your doing small projects look at the biggest part you are powder coating and get an oven for that size. Later as you grow you can get a bigger oven. |
Everything you said 360 is off the wall!
I mean this nicely, and to provide information, not to be insaulting. First if you have power company supplied electric you already have 220v into the house. Any electrician that says otherwise is trying to rip you off! Unless you need something extra dificult like ripping out walls or running wires under a swimming pool, then any company that charges $800 to install a normal 220v outlet is ripping you off, period! You have two wires that are 110v and a common, and ground into your fuse/breaker box! Use one 110v wire and one common and the ground and you have 110v. Use both 110v and one common and you have 220v! That is all there is to that! I would explain 3 phase to you, but your aready confused enough about 220! Of course you need them wired to the correct conections though If you did not have the correct voltage then you must have been trying to run a 220v stove on 110v or a junky little extension cord! Try to fill your gas tank with desiel and see how well that works! Or if you have a desiel then fill with gas instead! About the same thing, it ain't going to work, and you could actually do a little damage trying! If it took 1 1/2 hours to reach 350, then go to someones house with a real working 220v stove and bake a pizza! Oven heats to 450 rapidly and the pizza is done in 45 minutes! Newer homes not having 220v is just plain bull unless your looking at solar power, and even most of those have it! The $400 110v oven will not save time compared to a working 220v kitchen stove. 220v is more cost effective even as it uses less power and has better performance. Why do you think they make 220v hot water tanks, stoves, dryers, aircompressors, and window air conditioners? They do make smaller 110v units in the above items for people who don't want to mess with connecting 220, or portable units as 110v because you can find 110v in any room anywhere that has electric. It is not better, just more easily available. Who's looking for an industrial unit? I think the average home user is looking for what works well at a low cost. Not something to bake an airplane If the cheapest used stoves you can find is $125, then you were looking at Sears and BEST BUY at the scratch and dent items, not used stuff! Used is stuff that is working well but being disposed of because they just bought a new improved model and don't need two! I have lived all over the country, from east to west, and never had trouble finding a good used stove, frig, washer, or dryer for less than $100 anywhere! Most the time I get them around $25 -$50 unless I am looking for nearly new and fancy, which you don't need for powder coating anyway. You generally get the same type garuantee with a used appliaince as you do with a used car! But much less to go wrong The 220v dryer I use now I bought used over 6 years ago and only cost me $15. It just broke the belt a couple days ago, so I will probably buy another used one, cheaper than buying the belt! I have 3 washers, all worked great when bought and still do, none cost more than $50. I have 2 frigs that worked fine, bought cheap! I don't use them, bought them to store welding rods and such to keep em dry. But they worked great when bought and still might if I plug em in? It ain't going to burn down your house unless you do it yourself! It either works or it don't! Most a bad one will do is pop a fuse or breaker, and rarley will they do that. Most often they just sit there and do nothing if bad! Often you can get one for free that one or two top burners don't work. You don't need those for baking anyway! Did you buy a hardrive for your computer for the size program you were installing, or did you buy larger so you could do more stuff later? You never buy the smallest you can get by with, sure you may only want to do water pumps today, but what you gonna do when you want matching valve covers and oil pan in a few months? Buy another larger $400 oven?? You always get a little more than you need so you can meet future needs also! Do you only buy 2 gals of gas each day because that's all you need to get to work and home again? Or do you get a little extra in case you need to go elsewhere also?? Get a 220v stove used, cheap, and it will be big enough for many parts. Also on the small parts you might even be able to do several at the same time! Learn a little basic wiring, and if you know what you are doing to be safe, you can even pull the parts from the stove and build what ever size oven you want! What is any electric oven? An insualted metal box, heater element, themostat, and a control to set the tempature. That's all any electric heater is. Dryer has a drum and motor to bounce the clothes, but the heat is the same. Toaster oven, hot water tank, deep fryer, all the same thing, just different parts! I build most of my own equipment myself like that for odd uses. If you know what you are doing it is perfectly safe, and if you don't know then DON'T do it!!!!!! I have an electric dryer I use to dry sawdust for a specail use, built it from junk parts to meet my needs, about $25! I could have bought a smaller kiln to do smaller loads of the same stuff for around $700, but why?? Chromo |
But if your going to bash someone beucase they made a comment about buying a new oven then opposed to a used one! Then it sounds like you spend to much time knowing it all! Maybe some of us don't want to go looking all over gods green earth trying to find some $35 oven! I gave the guy an option and you came here and bashed me for it! What kind of board is this, I would not recomend this forum to any one if this is the type of response you get for posting. |
Sorry if it seemed I was bashing you, was just trying to make the points about what I was saying clear. Sometimes I don't sound as polite and friendly in these typings as I mean it. Hard to tell a persons attitude when reading text, the spoken word is much easier.
My apologies! The part about the 220v and 3 phase was meant to be joking, not insaulting, so were a couple other things, again my apologies. Yes I know Vegas is expensive on lots of things! Been there, done that! Lauflin,NV (however it's spelt) is somewhat cheaper and only about 90 miles away Ya, if your to close to VEGAS I suppose I could see your power problems! With all those casino's and the strip eating power like that I wouldn't be too suprised if a toaster had problems at times But that is not a normal or average case in general. I like the desert and the colorado river is pretty nice too, and close! I don't mind a 100 mile drive. Been thinking about getting a desert place myself, but not too close to a big city. I was reffering to the WHOLE USA in general, whereas you were replying about just Las Vegas I geuss. As far as seaming to be a know it all, perhaps I can come acrossed that way at times unintintionally. If I could learn to spell and type better it would help For about the last 20 years or so, while everyone I know is sitting in front of a TV rotting thier brain 5-6 hours at night I have been actively engaged in various projects. To each thier own, everyone likes thier own thing! I read books and surf the net getting information on other hobbies and projects I would enjoy also. From building my own windmills, making my own charcoal, blacksmithing, producing methane gas to run a small engine, I know alot more than many people. But I do not claim to know it all, ever. My last batch of home brewed desiel fuel came out milkey and I don't know why Nothing wrong with watching TV, that's what most people do! Personally I watch a movie on tape or DVD once in awhile and that is good enough for me. I don't even have a TV hooked up now, watch the movies on the 3 computers I've built myself and family. I installed capture cards in them all for that purpose. Again, just what ever a person or family prefers. So while my friends are relaxing with TV, I am getting hands on experience at something or learning to do something new. They never have time for anything because their favorite show is comming on. Yet they call me to ask why something doesn't work, or if I will fix it for them. So I guess in my circle of friends I am kind of the know it all, they know it, so I am the one they always call for free service or advice I certainly do not know it all though! I was totally baffled and confused recently in a conversation about Thermal Necluleur Fusion! But I do know how to sepereate Water back into Hydrogen and oxegen for small scale fuel, or to float a ballon Chromo Knowledgable, but not a know it all |
That's cool..
Then you know that you can't just take any oven and use to cure powder coat. Yes it might work, but it's not feasible to do so. There is allot of risk when handling and curing powder coat. The dangerous mixture of Air, Dust, and a spark of Ignition (ADI) can cause a dust explosion... You can recommend buying a $35 oven to convert to curing powder coat. I wont! Why? I don't want to be blamed for giving the wrong advise that would cost someone there life or even big penalties and fines ($25,000.00 or more even jail time). It might not happen to you but what if your neighbor calls them because there is a strange odor coming from your residents. Don't take my word for it check out your local State Occupational Safety and Health Plans office to learn more about the powder coating laws. http://www.osha.gov/fso/osp/index.html
360air-- I'm looking at the oven you refer to right now and I am curious what you see that I don't? I see a metal box with insulation,3 500 watt electric elements,a thermostat controller and a fan oh and a stainless steel lining. What I don't see is an exhaust fans to remove the fumes, I see no explosion proof hinges and no door latch at all.I do see a vent in the top to allow for expansion of the interior air though,--- fume vent?
How is this different from a home oven in safety features? |
| quick and easy degreasing | customandsound | Electroplating Questions | 6 | 07-29-2005 03:50 PM |
| Calculating Surface Area, the Easy Way. | PrecisionPB | Anodizing Questions | 6 | 05-28-2005 02:56 PM |
| Am I missing something ???????? | TimeTravel | Powder Coating Questions | 2 | 09-15-2004 06:17 AM |
| Missing items | txturbo | Electroplating Questions | 2 | 04-30-2003 02:16 PM |
| Very easy to do!! | Tim Wiltse | Anodizing Questions | 1 | 10-07-2002 08:27 PM |
