Acid. Muriatic or battery acid.
Seans Zinc Plating page |
If your parts are small enough, vinegar will take it off, but it's a lot slower, since it's a weak acid, and dilute.
Muriatic is not expensive, can be further diluted, and goes a long way. Sean
Sean
Your actually absolutely right. I was just to try to match it to the rest of the saws color. The other reason was I didn't want to rivet the corners so I was going to weld them and that would make it ugly anyway. The applications I want to use it for is electrical box covers, compressor pressure switches (home made) Boxes that hold other various components, so this is not a isolated application. Thanks for the heads up though.
Welding it certainly has safety issues.
As for matching color, it can be painted. Just wipe it down w/vinegar, rinse, dry & paint. Sean
Either powder coat or paint.
Any plain zinc surface will oxidize. You just need to remove the oxides & reactivate the zinc. Wipe the part w/mild acid solution (vinegar, 5-10% muriatic), rinse , dry & paint immediately. Sean
