Hello, I am building a toolbox for my ATV out of diamond plate aluminum. I would like to powder coat it with transparent red. Anyone ever done this combination? What does it look like? What color is the transparent red? Will, it be close to "Honda Red", Fire Engine Red, Milwawkee Drill Red , or is it sort of maroon? I saw a picture on the main page of a brake caliper (or something). It looked more maroon than red, could have been cause of the base steel color though. Thanks in advance for any comments.
CE |
the word says (transparent) wich means if you have a dark base you will have a dark red . it will reflect what ever is under the red .also if you put a heavy coat or double coat it will also be darker.
| I found sand blasting aluminum prior to powder coating is a big no-no. | mtumbleson | Powder Coating Questions | 59 | 04-07-2008 08:37 PM |
| Something for you die hard polishers out there to chew on | thesound | Metal Polishing Questions | 15 | 12-03-2007 01:16 PM |
| Fs: Turnkey Powder Coating And Ceramic Coating Business!!!! | Mcurtis7 | Used Items For Sale | 0 | 10-02-2005 03:18 PM |
| Do you have to use flash copper to plate aluminum | krsimulis | Electroplating Questions | 1 | 07-27-2004 02:32 PM |
| Need help with Polishing Aluminum Diamond Plate, real bad. | fireman | Metal Polishing Questions | 2 | 06-08-2004 09:25 PM |
