Old 01-21-2007, 07:06 PM
boston_jake01 is on a distinguished road
Default better taping way
I powder coated these heads and I also polished the edges.
I first polished the edges and then taped the edges (whichwas a pain in the ass ) then I pwder coated them, after it cool down I removed the tape and found that the powder got in some area I taped I had to repolish the edges and when I ran the buffing wheel to close and hit the coated areas it turned black ( Iguess from burning it ) the picture is not to good. I am really anal and dont like to see any pwder where it should be. any Idea on how to do this better?
Rich
project 1
http://www.freewebs.com/boston_jake01/index.htm
Old 01-21-2007, 08:03 PM
autoshopowner's Avatar
autoshopowner is on a distinguished road
Default Re: better taping way
I think what I am going to try is to shoot powder on the whole thing, then before I cure I will wipe the power of the edges of the fins. What do you guys think? Will that work? No taping at all.
Glenn R. Lever
Rochester, New York 14617-2012
My Cars http://www.leverfamilysite.com/vehicles.htm
Control arm Info http://www.leverfamilysite.com/GM_A_body.htm
Join us July 6-8, 2007 for the 5th Annual Northern Chevelle Gathering, Niagara Falls, NY!!!
Old 01-21-2007, 09:48 PM
that's the way i do it
powder it and before curing
clean up the edges with your fingers or with a Q-tip
has never failed and I've done like 10 this way.
Old 01-22-2007, 03:28 PM
I will try it that on the last jug, I will post the result this week.
Thanks
Rich
project 1
Old 01-25-2007, 09:48 PM
KeithLambert7
Yup. That's how I do it too. You can also use one of those cheap foam paint brushes to make it easier. I've also used a scotch pad to rub off the power on the edges afterward. They make em for a drill or wheel and that speeds it up. Both work pretty well.
Old 01-26-2007, 03:37 PM
Here's a head I just did, using the Rol-Loc surfacing pads in an air grinder. The Rol-loc's take off the powder pretty easily.
Dan Pesonen
Forest Grove, BC Canada
Personal motto:
Old 01-26-2007, 04:15 PM
Ok, so now the whole thing is power coated, the fins have been cleaned, can I then shoot clear on top of the cleaned fins and original power coat. Will the bear metal turn a color because of heating the item again?
Glenn R. Lever
  #8 (permalink)
Old 01-26-2007, 05:58 PM
Aluminum, no. Harley cyl's are alum. Now steel, I dunno? Never cleared bare steel. Good Q though. I do have some low temp clear, 340* cure temp. Got it from EW.
Dan Pesonen
Personal motto:
  #9 (permalink)
Old 01-27-2007, 05:50 PM
ok only thing is the rol loc will screw up the polished edge.
I will try to wipe it off on the last jug I have and then post the results.
Rich
project 1
Taping over cured powder for a second color corecoatings Powder Coating Questions 3 06-21-2005 07:07 AM
Taping & pluging KZjim Powder Coating Questions 2 10-11-2004 12:02 PM
