Old 01-28-2007, 09:58 PM
krymis is on a distinguished road
Default problems
I have a valve cover I am doing. It has a coating on it. I wire brushed it and blasted it. It looked good so i polished the letters and fins. I cleaned the whole thing with brake clean. Outgassed. Then sprayed the super chrome base. let cook 395 at 15min. after pulling it out i saw a few missed spots of the prior coating. other than that it looked good. so i figured i wanted to see the final product and sprayed the lollypop blue on. When i pulled it out there were fish eyes and little sections that did not take the powder or it pulled away. It looks like dung.
I would like to know a full prep shcedule you use from taking the part in to fished delievery. I need to know what to use to clean the part and then clean off any polishing residue. then clean the part befroe the coatings go on.
Dye problems with bead blasted finishes Easttex Anodizing Questions 17 12-14-2004 01:18 PM
Follow up to Copy Cad problems 69t120 Electroplating Questions 1 09-06-2004 09:31 AM
Problems using 12asf and 4.5asf! Chevalier Anodizing Questions 3 02-04-2004 08:55 PM
Does grease in the electrolyte cause problems? M_D Anodizing Questions 5 01-23-2004 03:11 PM
Consistency Problems NeoMoses Anodizing Questions 6 12-13-2003 03:01 PM
