Old 01-28-2007, 09:58 PM
krymis is on a distinguished road
Default problems
I have a valve cover I am doing. It has a coating on it. I wire brushed it and blasted it. It looked good so i polished the letters and fins. I cleaned the whole thing with brake clean. Outgassed. Then sprayed the super chrome base. let cook 395 at 15min. after pulling it out i saw a few missed spots of the prior coating. other than that it looked good. so i figured i wanted to see the final product and sprayed the lollypop blue on. When i pulled it out there were fish eyes and little sections that did not take the powder or it pulled away. It looks like dung.
I would like to know a full prep shcedule you use from taking the part in to fished delievery. I need to know what to use to clean the part and then clean off any polishing residue. then clean the part befroe the coatings go on.
Old 01-28-2007, 11:06 PM
Default Re: problems
Did you shoot the lolly Hot? I have had that a couple of times, but usually it's from oils still left in the substrate. Maybe oil/water in your airline?
Dan Pesonen
Forest Grove, BC Canada
Personal motto:
Old 01-29-2007, 01:45 PM
I shot the blue cold because of the polished letters and fins. I wiped the powder off with a damp spong. Usually i shot the candies hot at about 150-180.
Dye problems with bead blasted finishes Easttex Anodizing Questions 17 12-14-2004 01:18 PM
Follow up to Copy Cad problems 69t120 Electroplating Questions 1 09-06-2004 09:31 AM
Problems using 12asf and 4.5asf! Chevalier Anodizing Questions 3 02-04-2004 08:55 PM
Does grease in the electrolyte cause problems? M_D Anodizing Questions 5 01-23-2004 03:11 PM
Consistency Problems NeoMoses Anodizing Questions 6 12-13-2003 03:01 PM
