Electrostatic Spray (Corona) Method - the induction of powder particles exposed to an electrostatic field generated by a high voltage device.
Triboelectric Spray Method - powder particles receive an electric charge through the use of frictional contact with a nonconductive material. It's my understanding that it's easier to spray metallic powders using the Tribo method. I've never used Tribo, so I really can't help you much. One thing I do know is that if you are using the Tribo Method you must specify Tribo powder when ordering. Using the Corona Method it doesn't matter. You can spray Tribo powder using the Corona method. |
I had the same Q when i was getting my first nordson gun
I'll tell you what i was told tribo guns charges the powder better but it coats at half the speed of the corona and you can only use epoxy powders or tribo treated powder . so I bought a corona and i have never had any problems and i shot any powder with it . the only draw back i have seen is that metallic powders wear out the resistor on my gun so i just keep a spare around . also try to get a gun that you can get replacement parts easily |
The corona gun will be a bit expensive to add to the setup. That is the reason it is going cheap. The guns have the voltage multiplier built in them and that is the real expense for the corona upgrade. My advice would be to check with the manufacturer to see how much the corona gun will be.
Jason Williams |
many thanks you guys for a quick responce,i am going to do a bit research now and then maybe put in a bid if all is ok, i will keep to corona charging as a beginner.i'll keep you all posted as i want to have a shot at sand blastin my first parts this weekend...
thanks Grommit |
for nordson guns
a multiplier is about $1000 a resistor can be bought as a generic replacement for about $60 and a cable rebuild kit for about $80 and you need to send your cable in |
| Powder not charging | blackcamaros | Powder Coating Questions | 8 | 05-13-2006 04:14 PM |
| Tribo Vs. Corona | mkminoia | Powder Coating Questions | 6 | 02-28-2004 07:20 PM |
