Old 02-12-2007, 02:29 PM
autoshopowner's Avatar
autoshopowner is on a distinguished road
Question help, how do I get these areas to cover with powder
Please see that attached photos.
Look closely at the pictures and make suggestions on how to get powder on the areas that are not being covered.
I have tried low voltage, high voltage light powder, and heavy powder.
The only thing I have not done is to heat the wheel and then shot the powder. I really do not want to do that because if it does not work then I really have a mess. Right now all I have to do is blow the power off and try something else. (I have tried heating between attempts. There is nothing on the metal as I have had it in the sand blast many times thinking there was still primer on the wheel.)
ID:	569  help-how-do-i-get-these-areas-cover-powder-p1010007-2-.jpg.JPG
Glenn R. Lever
Rochester, New York 14617-2012
My Cars http://www.leverfamilysite.com/vehicles.htm
Control arm Info http://www.leverfamilysite.com/GM_A_body.htm
Join us July 6-8, 2007 for the 5th Annual Northern Chevelle Gathering, Niagara Falls, NY!!!
Old 02-12-2007, 06:23 PM
Harleydad's Avatar
Default Re: help, how do I get these areas to cover with powder
Are you trying to get in near the outer ends of the spokes?
Old 02-12-2007, 09:38 PM
Yes, if you look closely at the photo you will see where the metal has no powder on it at all.
Glenn R. Lever
Old 02-12-2007, 11:03 PM
Harleydad's Avatar
That is a tough area (Faraday Cage effect). I would try a bit more powder and less voltage. Get fairly close to the part and shake the tip of the gun in a short quick side to side motion.
Here's a trouble shooting guide, look at section 2.6.
http://www.tiger-coatings.com/filead...guide2_usa.pdf
Old 02-13-2007, 10:42 AM
coleman5 is on a distinguished road
try removing the deflecter tip that work for me makes the powder come strait out
Old 02-13-2007, 02:52 PM
bobpeckham's Avatar
bobpeckham is on a distinguished road
I plan on doing the rims on my kids motorcycles and I also plan on taking the spokes out then relacing them when done. I would recommend that method even though it is a pain in the you know what. I doubt this helps your immediate need but I know it is probably the better method.
Bob Peckham
www.teamdiggerracing.com
Old 02-13-2007, 07:37 PM
callmej75 is on a distinguished road
Send a message via Yahoo to callmej75
Heat it up to about 200* and pull it out of the oven, set your gun at its lowest voltage and about 20PSI air, and shoot it in them areas first. Might wanna experiment as the wheel is hot and stepping the voltage up slowly. Sometimes it will wrap better when its hot.
  #8 (permalink)
Old 03-08-2007, 02:28 PM
Here is an update. What I ended up doing was preheating to 190, removed the ground, dropped the voltage to 35K, dropped the air to 15 pounds and had the powder flowing as fast as I could get it to go (filled the cup up to 3/4 full)
I shot the power at a 45-degree angle going one way around the wheel then at a 45-degree angle going the other way around the wheel, flipped the wheel over and did it all over again. If interested I will be posting my wheel jig in that thread shortly. Thanks for the help.
The black band in the inside of the wheel is a rubber strip put there by the wheel manufacturer to seal any air leaks that might take place around the spokes. I called them and was told that the heat would not affect the rubber and it did not.
If I ever do spoked wheels again there will be a premium charge to do them.
help-how-do-i-get-these-areas-cover-powder-p1010004.jpg  help-how-do-i-get-these-areas-cover-powder-p1010007.jpg
Glenn R. Lever
  #9 (permalink)
Old 03-13-2007, 03:32 AM
precise is on a distinguished road
removing the deflector helps out alot , I remove it for doing motorcycle jugs,, that way i can get down into it more,, Did you PC the inside of the rims with the hanging system yuo are useing
  #10 (permalink)
Old 03-13-2007, 09:52 AM
The gun I use is a Red Line Alpha. It has a set of tips, one of which points all the powder straightforward, very much like a paint spray gun. I use it all the time and like it better then the normal diffuser.
Yes I used the stand to do the powder coat on the wheels. I do the backside first. Then flip the wheel over and do all of the rest of the wheel. Works really well.
Glenn R. Lever
copy cad power problems....I think?????? lintmann Electroplating Questions 9 10-20-2006 11:39 AM
Using 2 power supplies hurricaneracing Anodizing Questions 2 09-17-2006 10:30 PM
When the power goes out? luminous Anodizing Questions 3 05-23-2006 04:52 PM
anno power supply jasonboulanger Anodizing Questions 2 01-07-2005 05:48 PM
Anodizing Power Supply Q's jnbsystems Anodizing Questions 7 10-02-2003 10:33 PM
