FREE POWDER COATING SYSTEM
HV Powder Coating System
Buy Now
Old 02-20-2007, 10:54 PM
l24x4 is on a distinguished road
Default heat tape leaving lines
fully cured first coat then taped off around the letters using heat tape powderd them,but let it cure then pulled the tape off and it left lines where the tape was at,should i have pulled the tape off after flow out? and how do you get rid of the lines it left. thanks
Old 02-21-2007, 12:59 AM
fl70 is an unknown quantity at this point
Default Re: heat tape leaving lines
Heat the cover until the powder just starts to melt but not fully flowed out. It's important not to let it get too hot so the tape won't leave adhesive on the surface.
Remove it from the oven and allow it to fully cool. It's important to let it cool all the way to room temperature. After cooling, carefully remove the masking materials. Take a blow gun and blow off any powder that may have flaked off onto the first coat. Put the cover back into the over and fully cure the letters.
It ain't your grandma's box!!
Aluninum heat transfer rate. levi Powder Coating Questions 6 10-14-2006 11:05 AM
aluminium motorcycle wheels - pc'ing cause failure? mtnbiker Powder Coating Questions 32 03-26-2006 09:04 PM
tape customandsound Powder Coating Questions 3 06-16-2005 09:41 AM
hi temp tape shrinking craigcraig Powder Coating Questions 10 11-27-2004 11:04 PM
brake lines sageit Electroplating Questions 1 03-10-2002 12:02 PM
