FREE POWDER COATING SYSTEM
HV Powder Coating System
Buy Now
Old 03-02-2007, 06:35 AM
JTW37's Avatar
Caswell Platinum Member
Question About coating an Intake Manifold ???
As posted the other day, I powder coated an intake manifold, and the results were acceptable. My question: when I was checking the temp of the intake, for flow out, I was getting several readings from it. If I checked it toward the center, it read high. If I checked it toward the front or back, it read lower. One area read higher then 392 deg (403) and others read around 350-380. How am I supposed to know when flow out has happened? A bit confusing. Should I have waited on the lower temps to reach 392 or go with the higher reading?
Old 03-02-2007, 02:59 PM
Default Re: About coating an Intake Manifold ???
I kind of take an average. If the lower temps are alot colder, then wait till they get closer. MOst powders ahve areally good overbake, up t a Hr for some powders. SO, the areas that reach cure temp first are not going to overcure by the time the other areas cure. Most powders start flowing at 360F as well, curing at 380. Lower cure temps, just mean longer cure times.
Odball thickness parts like manifods I allways find easier to preheat them as well. the part re-heats a little more evenly it seems
Dan Pesonen
Forest Grove, BC Canada
Personal motto:
Old 03-02-2007, 06:15 PM
JTW37's Avatar
That's pretty much what I did. Just tried to average the temps. Just wondered if I was screwing up or not.
Thanks!
Old 03-02-2007, 09:09 PM
Harleydad's Avatar
That seems high to me.
Old 03-02-2007, 11:32 PM
Can';t remember where, but I read that somewhere, and am just passing it on.
Dan Pesonen
Personal motto:
What is the best coating for the inside of an exhaust manifold? x1rider Powder Coating Questions 7 01-03-2007 10:06 AM
Intake Manifold PC ?'s TravisT Powder Coating Questions 4 03-17-2006 06:29 PM
aluminum intake manifold preparation bones Powder Coating Questions 4 09-29-2004 07:53 PM
polishing an intake manifold payneronte Metal Polishing Questions 0 05-04-2004 01:04 PM
Problems with LT1 Intake Manifold thesound Metal Polishing Questions 4 11-16-2003 08:54 PM
