if they are not you will not have a good result (fish eyes .rough finish or lots of orange peel) |
cool.
the fade that i want to do looks like this, ill link http://www.archerythai.com/assets/images/Agulla.gif |
different ways of doing fades but here is how i do mine
valve cover example hang the cover , lower pressure in gun to imit the size of powder cloud start powdering red from the top going down to 1 inch past the middle of the cover then clean the gun and reload with purple , start powderring from bottom going up til 1inch past the middle to overlap on the red put in oven and cure. once it is cured you can put an extra coat of clear on top if you want more shine to it |
might not be able to do all in one shot. might have to do the a base color then cure then the other colors and fade then cure again. |
just 2 posts above your post i explained how i did it |
I tried it and failed using the same technique baz used. I'll have to try better next time. I couldn't get the powder to stick on the 2nd and 3rd coats.
I'll strip and try again. It was my first attempt. |
| Powder not sticking on second coat! | ur2slo | Powder Coating Questions | 1 | 02-17-2007 09:33 AM |
| powder coating over powder coat? | corybarta | Powder Coating Questions | 6 | 08-21-2006 09:15 AM |
| Two Tone Powder Coat | engineerscott | Powder Coating Questions | 5 | 03-27-2006 12:44 PM |
| Finding a place to powder coat | RCLSolutions | Powder Coating Questions | 3 | 05-04-2005 10:42 PM |
| Laser printer = Powder Coat Printer? | tbloss001 | Powder Coating Questions | 11 | 08-30-2004 07:08 PM |
