It ain't your grandma's box!! |
The tanks are only pressurized to 10-25 psi. The PA stands for "pressure assisted". These are much safer to operate than conventional pot blasters. I have considered building 3 or 4 of these pvc setups and putting different media in each with switching valves to change between medias. Just dump whats in the cabinet and switch to the next media.
Jason |
Did anyone try my design? - Let's hear about your results.. thank you all 10-fold.. - Just found this post too!
and thank you JT and cdaeme- Glad to have you as members.. Rob
My site & DIY Groups:PABLASTER - Rob's Projects - Powder-Coating - Metal-Casting - Lathe Group - 1930's Chevys - Fiberglas' - CNC Tables - GOT LINKS??
Soon, very soon. |
I tried the PA blaster, didn't seem to work that well, but then again, I think I had a regulator problem. I am going to re-try it again, I think
Dan Pesonen Bandit Powder Coat <<From Powder to Perfection>> Forest Grove, BC Canada Personal motto: "If it ain't broke, modify somethin till it is" |
| Plating, Powder Coating, Media blasting, Polishing, Machining, fabrication welding... | arrowheadracinginc | Services Offered/Wanted | 4 | 03-17-2007 08:24 AM |
| got new compressor-what blasting media to use? | grommit | Powder Coating Questions | 7 | 02-15-2007 10:08 AM |
| Media Blasting | BigDog | Electroplating Questions | 5 | 02-06-2005 12:25 PM |
| Question about media blasting. | berad001 | Metal Polishing Questions | 1 | 02-05-2005 12:29 AM |
| Media blasting?? | trsick | Powder Coating Questions | 4 | 02-02-2005 11:03 AM |
