FREE POWDER COATING SYSTEM
HV Powder Coating System
Buy Now
Old 03-08-2007, 10:25 PM
JTW37's Avatar
Caswell Platinum Member
Exclamation Media Blasting Solution 5 Star!!
I've been reading many, many post here and on other Forums, just so I can get a handle on this powder coating. Believe me when I say, you guys are really full of it. Information and learning for dummies like me. And I'm glad you are full of it.
So I guess it's my turn to try and contribute to this forum that has been of so much help.
Media blasting seems to be a big concern of many on here and elsewhere. And it should be. Bad media blasting makes for a bad finished product. I've painted cars for many years and the beginning is the means to a great end. Same for powder coating. so, here is my contribution.
There is a true way to do media blasting and you won't believe the results. Nope, I don't have any connection with it and don't get paid any money. The setup is so simple, I can't imagine no one thought of this before now. I'm actually enjoying media blasting!!
Anyway, I will provide you with the link to a web site that explains it more. You will have to invest some money in it to get started. Ahh, the catch. Nope, no catch. The amount is $9.99 and you will become part of yet another forum. But, like here this forum is a good one.
I have this blaster and I'm here to tell you, IT DOES WORK and very well I might add. Okay, enough of the gabbing. Go to this web site and read it. Then invest the $9.99. You won't regret it. And after you find out what you been missing, I will except donations. just kidding.
Go here: www.pablaster.com
Now go! no more messing around.... and bring back some feedback.
JT
Old 03-08-2007, 11:06 PM
cdaeme's Avatar
cdaeme is an unknown quantity at this point
Send a message via AIM to cdaeme Send a message via Yahoo to cdaeme
Default Re: Media Blasting Solution 5 Star!!
A few of us here have PA Blaster setups already. Glad to see others with good results. Rob is a great guy to deal with. Thanks for bringing this back to the top for all to see.
I have mine plumbed right into my blast cabinet and it is great.
Jason
Old 03-08-2007, 11:28 PM
toxic is on a distinguished road
So from reading the site it's a pressure tank for the media with a control valve on it?
Old 03-09-2007, 01:27 AM
XK120DHC
Sounds like it..
I'm not knocking another person's deal or product, but I've been restoring cars, including sandblasting, for over thirty years and I can tell you, one doesn't need "tricked-out widgets" to achieve the proper finish, or "tooth" on the metal, one only needs a proper sized/rated compressor, a pressure sandblaster (100lb capacity min.) and a load of experience.. which comes with time!
An idiot with a sandblaster is just as dangerous as an idiot with a gun or a back-hoe, an SUV, etc.
Most folks make the mistake of trying to "bore holes" with a sandblaster, then bad-rap sand for warping their panels.. done right, one can sandblast the "Garnish Molding" (inside, around the glass trim) and produce a perfect "Satin Finish" on the metal, and not damage the parts.. one only has to use Blasting Sand (not playground sand) that's been run thru the blaster about four times, then turn down the air at the pressure tank to 40 or 50 psi, set the "Sand/Air mix" so it's not all air, nor "heavy" with sand-- when blasting, you will hardly see the sand being sprayed-- then hold the nozzle about 12 to 18 inches away from the surface and at a "low" 50 to 60 degree angle relative to the surface being blasted.. you will see the layers of paint & rust literally disappear before your eyes.. On multiple layers of paint, DON'T try to remove all of them in one pass.. this can overheat, and warp, the panel.. Keep the nozzle moving.. if possible, place a bare hand on the backside of the are being blasted.. if you feel the metal getting warm, move the nozzle a bit faster.. Simple, huh? Also.. NEVER sandblast off "tar" undercoating.. this only drives the oils into the "grain" of the metal and will guarantee that the paint will peel off immediately AFTER the car is completely finished!!
I start out with between 500 and a thousand pounds of #4 Blasting Sand (only "Silica Sand"-- white "ash tray sand"-- is "finer", aka smaller in grit size. It is also more expensive and has a higher risk of causing silicosis!), purchased from the area Contractor Supply house (about $8-$10 per 100lb bag) then I blast the "hard parts" like the chassis, suspension pieces, cast iron items like the differential, etc., sweeping up and "filtering" the sand-- I call this "Recycling the sand"-- a couple of times as required (one must have an enclosed area with a smooth concrete floor!), then blast the body shell, doors, hood and trunk lid.."recycling" the sand as required.. by this time that 500 to 1000 pounds of sand has the texture of a very fine grit powder, that's when I blast the "delicate" items like the windshield trim, nuts, washers and bolts (especially if one is trying to preserve the original fasteners as well as the "Head Stamps" on the bolts.. Brit cars of the '50's/'60's used "BEES", "Rubby-Owens" "R-O", etc. and these are near impossible to find!!).
It's as simple as that.. No need for "exotic" slags, powders, "magic elixirs" or "secret plans" to build a pressure blaster that all claim to prevent metal damage, etc.
Of course, it should go without saying, but it doesn't, given the number of idiots who don't understand what "Taking Personal Responsibility" means, that one MUST take proper safety precautions.. Personally, I "suit-up" in a Tyvek "onesie" (hood to booties jump-suit I get from Grainger), mid arm length rubber gloves--I pull the suit's sleeves over the gloves, a dual cartridge respirator with dust pre-filters, and a Blasting Hood.. I even make my own "Tear-Offs" for the viewing lens.. a local plastics supplier has Lexan in various thicknesses, I get 0.020".. a 3'x3' sheet of the Lexan makes a lot of Tear-Offs for the price of a couple of viewing lenses.. I just tape them on with masking tape, after they are so "frosted" that I can no longer see clearly (about two hours), I replace the tear-off.. Is that too simple, or what? I use the same Lexan on the Viewing Window of my Bench-top Blast Cabinet... I also use the same Pressure Blaster in my Bench-top Blast Cabinet, which is a small "cheepie" (plastic!) H-F unit (about 24" wide, 18" deep and 12" tall), and I've used it a LOT over the last ten years.
Many folks do as Shakespeare said.. make "Much Ado About Nothing".. just use Common Sense.. Ben Franklin said something like that..
On the "enclosed area", this needn't be a super-tight, seperate building, although that would be nice.. I go to a home improvement store and buy a box or two of 20'x100' 4mil clear plastic sheeting and 1"x2" Furring Strips and simply enclose a corner of my 1500 sq ft shop to use as the Sand Blasting Area.. I try to cover the ceiling and walls in a seamless fashion, this greatly reduces the fine dust filtering out into the rest of my shop.. I simply lift up the sheeting to roll in a car body on a rotisserie or a "rack" of suspended body parts, and sandblast away..
Being in Texas, we have the luxury of having several low humidity days in a row.. this allows one to blast, clean off/out the sand (use a shop vac) as nearly complete as possible.. I then use bits of masking tape to cover all the bolt/screw holes (to keep the dregs of sand from getting into the new paint!), wipe down the parts with PPG's DX330 Cleaner/Degreaser, Tack Off then, using an HVLP gun, prime with PPG's DP Epoxy Primer.. I use the same proceedure for parts to be Powder-Coated.
This is the "system" that I have worked out over the years, it works well for me and I have no doubt that some enterprising folks could improve on my "system".. I just hope they are willing to share their improvements with everyone else..
Charles.
Old 03-09-2007, 06:39 AM
Sportster is on a distinguished road
[quote=toxic]So from reading the site it's a pressure tank for the media with a control valve on it?[/QUOTE
Yes it's a pressure tank for the media, Yes there is a control valve on it, in fact mine has 4 different control valves. No those valves are not the magic. No it's not a widget. It's a great working blaster.
Old 03-09-2007, 06:41 AM
JTW37's Avatar
Wow! The whole point of this post is to help the DYI'r get his blaster setup so he can regulate the sand and air better. And it DOES work better. We are NOT all professionals here. I think it's safe to say, the majority of us are " Do it yourselfers" As for restoring cars for years, so have am I. All I'm trying to do here is point out a really nice alternative to those who have a bitch of a time trying to get those crummy a** sand blasters to work like they should. And this way fits nicely in the pocket book ($$$). I think over 1000 guys that have taken up using "the widget" says plenty.
Sorry you don't agree with making it simpler for the DYI'r. Most of us are small time and don't understand the usage of the blasting. As for media, silica sucks and is dangerous. It don't get used by me.
Do it the way you want and the others will take note and have a look at a system that works, BETTER then the alternative. And it's a 45 deg angle...
End of rebuttal!!
Old 03-09-2007, 09:14 AM
Harleydad's Avatar
Is this PA Blaster something that works in conjunction with a siphon feed cabinet or can you construct a blasting room (say 8'x16') and it will work.
  #8 (permalink)
Old 03-09-2007, 12:25 PM
cdaeme's Avatar
It can be constructed to work in a blast room as well as a cabinet. This is mainly some modifications that can be made to a normal pressure pot blaster or you can build your own. I built mine from a 30 gal hot water heater tank, and it will hold 300 lbs of black beauty, all for less than $60. The nice part about the PA Blaster is you have a lot more control over the blasting.
Jason
  #9 (permalink)
Old 03-09-2007, 01:38 PM
callmej75 is on a distinguished road
Send a message via Yahoo to callmej75
So how much does it cost for materials? This sounds pretty good...I might get convinced to invest in it.
  #10 (permalink)
Old 03-09-2007, 03:51 PM
JTW37's Avatar
The initial investment is $9.99 for the plans. After that, the cost will vary depending on how good of a scrounger you are and a DYI'r. The gauge can be gotten through the forum, as can the regulator. But if you get the plans and read through and ask questions on the forum, most of your questions will be answered. Basically, if you look at what Harbor Freight gets for the big Pot Blaster ($199.00), you can build your own for a lot less money AND it will be made in the good ole USA.
This system was well thought out and has been tried and is true...
I don't put out information if it isn't any good or tried by me.
That's all there is to it and I see I have backers.
What's $9.99 amount to now days anyway. 3 gal of gas, a couple packs of smokes, a few long necks ?
Plating, Powder Coating, Media blasting, Polishing, Machining, fabrication welding... arrowheadracinginc Services Offered/Wanted 4 03-17-2007 07:24 AM
got new compressor-what blasting media to use? grommit Powder Coating Questions 7 02-15-2007 09:08 AM
Media Blasting BigDog Electroplating Questions 5 02-06-2005 11:25 AM
Question about media blasting. berad001 Metal Polishing Questions 1 02-04-2005 11:29 PM
Media blasting?? trsick Powder Coating Questions 4 02-02-2005 10:03 AM
