sure blasting works well or depending on the piece you can use chemical strippers too.
SouthWest Powderworx Tyler Nutter 5054803934 www.swpowder.com myspace/swpowder tyler@swpowder.com |
I have been using glass grit in my cabinet and it takes like 10 min just to blast a small 6X6 inch bracket both sides. Chemical stripping is a pain unless the part is easy to scrape afterwards. Having to strip powdercoating is the worse part when doing powdercoating! LOL
I have learned that when recoating a powdercoated part just etch the old part in the cabinet and coat on top. I have had no problems at all. Last edited by NXGHOST; 03-23-2007 at 04:57 AM. |
i have made a striping tank was exspencive but works great takes about 20 min to strip 3 coats
5 gal 1012 desolver $216;00 old steel utility sink diafram pump $30:00 fittings home depo $30:00 filter $20:00 |
Any more info on the "1012 desolver"? I tried googling it and can't come up with anything. I am looking for a good Liquid paint rempover/stripper I can make a soak/dip tank with. FOr parts Valve cover size and smaller. I don;t know if any of you have tried to remove the factory coating on Polished Edelbrock valvecovers. Inside the fins. It is a REAL pain with jelly type stripper. I need something I can soak Alum/steel parts in for even overnight to dissolve the paint/old powder. Got to be availible in Canada too.
Dan Pesonen Bandit Powder Coat <<From Powder to Perfection>> Forest Grove, BC Canada Personal motto: "If it ain't broke, modify somethin till it is" |
You have to email them for a shipping quote.
It ain't your grandma's box!! |
I just got done trying a new way (new for me anyway) of stripping a powdercoated Valve cover. Put in in the oven for 30 min at 500 and there is simply nothing left! If burned away! Any remaining trace blew clean off with the quick pass in the blast cabinet. If you dont have a blast cabinet a quick power wash would have done the trick.
| Fluidized bed stripping for cured powder | ublinkd | Powder Coating Questions | 6 | 10-31-2006 08:43 AM |
| powder coating over powder coat? | corybarta | Powder Coating Questions | 6 | 08-21-2006 08:15 AM |
| Two Tone Powder Coat | engineerscott | Powder Coating Questions | 5 | 03-27-2006 11:44 AM |
| Finding a place to powder coat | RCLSolutions | Powder Coating Questions | 3 | 05-04-2005 09:42 PM |
| Laser printer = Powder Coat Printer? | tbloss001 | Powder Coating Questions | 11 | 08-30-2004 06:08 PM |
