sup guys new here..
I am coating in a convetional oven that only the top elemnet works... the bottom one isnt working even on broil..... (lookin for a new oven right now) I have sprayed alot of parts such as grab bars for 4wheelers... the upper part closest to the element that works is awsome,perectly shiny and what not.... the underside looks as if it didnt get enought heat.. (kinda dry,texture look to it) if i got an oven that BOTH elements worked would this get rid of that dry look? thanks |
Can you move the good element to the bottom?
It ain't your grandma's box!! |
you should be able to swap the elements. they are usually only held in by 2 screws.
if i'm not mistaken, and i often am!, the bottom element should work on bake and the top on broil (or is it both on broil)? |
thanks guys... i just got done moving the good element to the bottom... im thinking that there may be something wrong w/ the wiring to the second element... what if i just spliced that second element into the one that works? as in jumped the wires from the good one to the second one!
If it does, splice them together.
| Extreme Chrome with Clear Coat How to... | hvac36 | Powder Coating Questions | 47 | 02-06-2008 09:57 PM |
| Two Tone Powder Coat | engineerscott | Powder Coating Questions | 5 | 03-27-2006 11:44 AM |
| Clear coat problem | sportster883r | Powder Coating Questions | 3 | 11-21-2004 04:52 PM |
| Powder Coat caught on fire! | Sleepr_Tech | Powder Coating Questions | 3 | 09-10-2004 06:22 AM |
| Second coat after a few days | tcjm | Powder Coating Questions | 1 | 03-20-2004 12:36 AM |
