Go Back   Caswell Inc. Metal Finishing Forums > Powder Coating Questions
Connect with Facebook
Closed Thread
Old 04-01-2007, 01:33 AM
precise is on a distinguished road
Default brake calipers
Has any body ever powder coated a set of calipers,, Or can it be done ,,
Old 04-01-2007, 12:13 PM
myillwillinc's Avatar
myillwillinc
Default Re: brake calipers
it can be done very easily. just make sure to clean the calipers very good. if they have any oil, brake fluid or rust on them it will bubble the powder. if u are doing them for ppl, i always run the idea from them to look at buying new ones from an auto parts store. they are fairly cheap and they are clean and ready to go after a wipedown. here is a set i played with the idea of lettering on them.
http://www.illwillinc.com/
PC'ing -> trods
Old 04-02-2007, 09:11 PM
What i was concerned about was the rubber seals on the calipers,, So the rubber seal will hold up
Old 04-03-2007, 02:43 AM
No, all seals and fittings need to be taken out. Competely disasembled. Everything you coat should be disassembled
Dan Pesonen
Forest Grove, BC Canada
Personal motto:
Old 04-04-2007, 01:11 PM
4birdman is on a distinguished road
They say you can tape off the piston seals and plug the holes and you're good to go. Calipers are made to take a LOT of heat and most of them have high temp seals, like Viton or similar.
I've done a lot of them and just made very sure to tape off around the piston and plug up really good. So far they've all been working.
Old 04-10-2007, 01:51 AM
nuttyman's Avatar
nuttyman
you're correct in that respect but I go the route of complete dis-assmebly. if you leave the seals in there is always the chance of trapped fluid behind the seals working it's way out in the oven.
SouthWest Powderworx
Tyler Nutter
5054803934
www.swpowder.com
myspace/swpowder
tyler@swpowder.com
Old 04-10-2007, 12:15 PM
Yeah, I had that happen on a set of calipers I was goofing around with. Brake fluid burns good in the bottom of an oven.
  #8 (permalink)
Old 04-15-2007, 12:28 AM
boston_jake01 is on a distinguished road
ya I agree I disassembled mine (bike) not hard.
Rich
project 1
http://www.freewebs.com/boston_jake01/index.htm
Closed Thread
Chrome brake calipers? PartTimer Electroplating Questions 7 10-18-2008 02:23 PM
Need good powder for brake calipers. Livinincolor Powder Coating Questions 0 05-02-2006 09:56 AM
OK one more time about Brake Calipers Noob2PC Powder Coating Questions 9 09-24-2004 09:28 PM
PC the brake calipers?? upncoming Powder Coating Questions 11 06-24-2004 10:51 AM
Brake Calipers and hubs mcarjeff Other Metal Finishing Questions 1 01-26-2002 09:58 AM
