Old 05-29-2007, 01:42 PM
cruizer's Avatar
cruizer
Default My latest coated part.
So it turns out that when you test a color on stamped steel, and then coat said color on cast aluminim, you get two different colors. Since I have never coated cast aluminum before, I did not know this. Needless to say, i was very very upset.
So i stripped the part and did some testing. To get the color I wanted, I did two layers of solar flat black. Then, since I wnated embossments done, I used colbalt blue for them. Then i topped it off with a Metallic grey. Turned out pretty nice!
This si the first time I have done embossments. And using the sponge technique isn't as easy to me as it seemed. But I got the job done, and I am fairly happy. Good thing it's for my own motor.
I also did a little polishing as well, first time for that too. Lots of work for just a few parts.
Old 05-29-2007, 01:43 PM
cruizer's Avatar
cruizer
Default Re: My latest coated part.
And the valve cover:
Old 05-30-2007, 02:36 AM
chromo
Just curious, those cogged pullies look nice, but are those timming pully gears that will behind a cover?
Looks almost like a 4cyl ford engine I had apart recently, that large bottom gear would be the oil pump drive?
Old 05-30-2007, 03:23 AM
Ya, light colors all vary shades depending on the base color. When doing multiple metals, in same color, best to start with a base color fro all. Just a heads up, White, lightenes color, makes them brighter. Silver makes them neutral, and Black, obviously darkens.
Dan Pesonen
Forest Grove, BC Canada
Personal motto:
Old 05-30-2007, 12:04 PM
cruizer's Avatar
cruizer
They are timing pullys. Normally they would be under a cover, but the cover now will only cover the bottom half of the motor. Of course I didn't realize any of this until after I did the work!
Obviously it's not a Ford motor, hence the VW symbol. It's a 1.8L for my Corrado G60. And the large lower gear is the oil pump, yes.
Old 05-30-2007, 10:05 PM
UrineMachine is on a distinguished road
Is it a 16v or a 8v? Isn't the G60 motor 1.6L supercharged or am I wrong (probably the latter)
Old 05-31-2007, 10:31 AM
cruizer's Avatar
cruizer
Stock, it's an 8v, the G60 is a 1.8L supercharged motor. You're close!
There are people who have converted these to 16v. But I don't have the money or know how to do so.
  #8 (permalink)
Old 06-01-2007, 09:37 AM
cruizer's Avatar
cruizer
Well it happened again.
This time I coated my intake for the motor. Also made of cast aluminum.
I did two layers of solar flat black, then the metallic grey. And it comes out of the oven silver. I was ****ed to say the least. Three coats of powder on this part are going to be a PITA to remove. I'm not even sure if it's completely possible due to all the crevices and stuff.
So the only difference between this one and the valve cover, was that the valve cover got 2 coats fo solar flat black, then colbalt blue, then the grey. Perhaps it's the blue that did it?
I was too ****ed to take pictures.
  #9 (permalink)
Old 06-04-2007, 05:50 AM
You need to take a picture of the valve cover and intake together, but I think I can see Blue in the valvecover, reflecting through the grey.
Dan Pesonen
Personal motto:
  #10 (permalink)
Old 06-04-2007, 09:33 AM
cruizer's Avatar
cruizer
Very interesting.
I am going to guess it's more of a reflection of the light on the valve cover than the blue showing through, only because I don't think I notice that in person. But I will take a picture of the two together. And I'll look again at the valve cover and see if the blue is showing through.
PLATING POT METAL............... 48Buick Plating Pot Metal 31 08-29-2007 12:40 PM
How well does powder stick to part before baking? chromo Powder Coating Questions 4 05-04-2007 12:22 AM
help getting coverage with irregular part R.B. Electroplating Questions 7 03-19-2007 01:15 PM
Part cleaning. nil8u Electroplating Questions 9 08-22-2006 01:23 PM
Part is 1/2 blue 4A, 1/2 Deep red. red fades when boiled frubino Anodizing Questions 1 07-27-2004 02:56 PM
