Old 03-13-2003, 07:12 PM
jmsandlin
Default can concrete be powder coated?
I am looking to powder coat concrete, can this be done?
Old 03-13-2003, 10:33 PM
Default CONCRETE
Why? What are you trying to acheive?
Old 03-17-2003, 10:33 PM
jmsandlin
I am trying to put a food grade coating on concrete that will take temperatures at boiling or slightly above.
Old 03-17-2003, 11:50 PM
Default Concrete
I have yet to see concrete powder coated, but hey why not. However, my concern is with the temps you are looking at. Water boils at 212F and with things mixed in, that may be raised slightly. But the heat applied to the concrete to acheive boiling point will be much higher. If the outside is coated and heat is applied the powder will not hold up to flame temps and most elements will burn powder if you use electric. I suggest you go with a liquid coating, but you need to contact manufacturers directly for the exact specs. There are high temp powders on the market but I haven't seen one sold as food grade yet and most can't go above 900 to 1000F.
Old 03-19-2003, 11:03 AM
marsfrogie
Send a message via AIM to marsfrogie
Try POR15. That can take temperatures in excess of 400degrees.
Old 05-10-2003, 06:10 PM
fredde
Send a message via MSN to fredde
Default Re: can concrete be powder coated?
Did you try it ? Please post results if you did
I would think it would be falling off in big pieces the second time you heated it up or
Old 05-17-2003, 08:34 AM
chromo
I never thought of powder coating concrete, but if it works might be interesting possibilities if you could get the powders cheap enough and could bake it somehow.
Sealing basement walls? Swimming pools? Those large cement birdbaths?
Baking would be a problem, but I wonder if it would hold up better than paint for concrete?
Chromo
Finding a place to powder coat RCLSolutions Powder Coating Questions 3 05-04-2005 10:42 PM
Pewter be powder coated? warchild Powder Coating Questions 1 02-14-2005 09:04 PM
Gun spitting excess powder pdeinc Powder Coating Questions 8 10-21-2004 04:21 PM
Laser printer = Powder Coat Printer? tbloss001 Powder Coating Questions 11 08-30-2004 07:08 PM
Types of material that can be powder coated. bryaneh Powder Coating Questions 1 03-03-2003 08:31 PM
