Hello,
I got my motorcycle fenders/gas tank pc'd. Colors are satin black and bare steel with a satin clear. Now 3 weeks later i notice this. It is because it is bare steel with a clear over top or what is causing this. Also can i put satin clear over bare metal and have it not rust?? ![]()
looks like the tins weren't completely cleaned and dry before coating, or that rust was already there. once properly coated, you won't get rust, whether you use color or clear.
on the lines, crisp lines require good masking. you're always going to have a 'drop off' point between the powder and metal though. thinner coverage will create less of an effect, and the clear can help mask some of it as well. |
Always wear latex or nitrile gloves when handling parts. You could give the bare area a light sanding after curing the satin black, wipe it down with pre, dry, then shoot the clear. For slightly cleaner lines, press the edge down firmly and leave the tape for the duration of the cure.
It ain't your grandma's box!! |
| Extreme Chrome with Clear Coat How to... | hvac36 | Powder Coating Questions | 47 | 02-06-2008 09:57 PM |
| Clear Coat - What to? | itsallgood | Powder Coating Questions | 4 | 02-25-2007 08:10 AM |
| cleaning brass before clear coat. | ovrundr | Metal Polishing Questions | 5 | 08-31-2005 12:45 AM |
| Clear coat problem | sportster883r | Powder Coating Questions | 3 | 11-21-2004 04:52 PM |
| reason for clear coat? | Jay87T | Powder Coating Questions | 14 | 03-20-2004 11:41 AM |
