Old 06-20-2007, 04:27 PM
mtumbleson
Default Just thinking..
I'm in the middle of a custom bike build and would really like to powder coat the entire bike. The only problem is the tins (fenders, tank, etc.) are not in perfect shape. I was wondering if anyone had tried applying a coat but not curing the powder completely, then sanding between coats?
I suppose I could buy one of the leading kits that can be powder coated, but they are a little pricey. I'm fully capable of shooting your standard automotive paint, but I've really grown to dislike the process now that I'm powder coating.
Has anyone tried this process?
Old 06-20-2007, 06:37 PM
nuttyman's Avatar
nuttyman
Default Re: Just thinking..
what shape r the fenders in? are they just dented, rusty or what? yes u can sand a coat & use it as a base. it is a common practice. u should allow it to cure fully though.
SouthWest Powderworx
Tyler Nutter
5054803934
www.swpowder.com
myspace/swpowder
tyler@swpowder.com
Old 06-20-2007, 07:49 PM
mtumbleson
All parts are new metal, unpainted, most are hand made.
I really didn't know it was a standard pratice. Everything is in pretty good shape, no dings and such. But hand made parts do need a good primer base for sanding...
I'll take your advice and do the full cure, thanks.
Thinking of an oven..... vintagespeedwerks Oven Building Forum 9 10-08-2006 08:47 PM
thinking of getting... rickjames Powder Coating Questions 1 04-16-2005 12:18 PM
Would using a stainless steel freezer body for a PC oven be bar_acres Powder Coating Questions 4 11-04-2004 08:17 AM
Im Thinking about buying the gun from Caswell Sezer Powder Coating Questions 10 12-28-2003 10:40 PM
