50kv Gun Question
I noticed yesterday part of my gun was sliding up the barrel. I don't know what it is called, but the metal piece inside the barrel with three points on the end is loose and will slide toward the end of the barrel. If I push it back in place, there seems to be a hard stop it hits. Anybody else have this happen? Should I be concerned? Do I need to glue or something?
Separate question: Will powder buildup on the metal rod and interior of the barrel significantly affect the charging of the powder?
Thanks
