Old 07-11-2007, 02:38 PM
UrineMachine is on a distinguished road
Default Jet Hot/Swaintech -- or better...Cerakote?
I really need to coat my turbo chargers exhaust housing - it has turned an ugly brown color due to heat and humidity im sure.
I have looked into getting it SwainTech coated or Jet Hot'd but they need the turbo housing for a long time - about 2 weeks on average. They also want to charge me $150 to do it.
Is there something that is durable enough to coat a turbo exhaust housing (temperatures might reach 1000 - 1200F.
Has anyone used the coatings? I want a silver or chrome look so I was looking at the chromex product the only issue I have is the steel wool/vibratory polisher portion - what does the product look like if not vibratory polished? I don't want to alter the geometry of my turbo housing internally or the openings.
Thanks guys.
I guess I could just go black, too. Hrm.
Here is the item I need to do:
Old 07-11-2007, 11:52 PM
Default Re: Jet Hot/Swaintech -- Cerakote?
Caswel's Satin Black ceramic will handle 2000*F. I have had the ceramic burn on is Turbo Snowmobile applications, but the Satin Black has been great. Spray with a HVLP gun and bake, no polish needed
Dan Pesonen
Forest Grove, BC Canada
Personal motto:
Old 07-12-2007, 12:09 AM
Yeah I already ordered the Chromex - I think I should be ok - my turbo is on an up pipe setup and I don't see it getting retardedly hot.
Old 07-12-2007, 01:12 AM
BottleFed70 is on a distinguished road
Sorry to get off topic here, but what does "Up pipe design" mean?
Old 07-12-2007, 02:55 AM
This:
Intermediary pipe between turbo manifold and turbo inlet like Porsche 951 and Subaru use.
Old 07-12-2007, 02:45 PM
Gotcha... Most V8 single turbo kits I've looked at use this design... never heard of it called "Up pipe" design tho.
Is there any benifit to this design? As I understand it, you want the turbo as close to the exhaust ports as possible.. as it helps with spool time and you don't want to dispurse any heat until after the turbo.
I'm hoping to turbo my classic mustang this winter... will probably be using an "Up Pipe" design myself.
Old 07-13-2007, 09:09 AM
autobonifica is on a distinguished road
Send a message via AIM to autobonifica
because of the layout of a flat 4 or flat 6 engines...you have to have an additional pipe. my wrx goes from the engine into the exhaust manifold...then to the up pipe, the turbo, the down pipe, the mid pipe, then the rear section.
notice i didn't say anything about cats
Reactive Coatings
  #8 (permalink)
Old 07-19-2007, 12:12 AM
JTW37's Avatar
Caswell Platinum Member
I have used the Cerakote and like how it does. But you have to be careful with it. Spray it on very light. If it gets to heavy, it runs and will leave trtacks where it ran. Next step, sandblast it off and start over.
Also, clean it real good before you sandblast, because after you sandblast it, you can't do anything but blow off the sand and then coat it. I found out the hard way and also got that information from the company that makes it.
You can polish it by hand, if you don't have a shaker or glass bead blast it. But be careful there as well. You don't want very much air pressure when you blast it, or it will ruin the finish and you get to do it over again. Had that happen also.
so I've learned a couple of hard lessons with it, but it great stuff. 1200 deg. If you coat inside and out, you get a better heat barrier.
  #9 (permalink)
Old 07-23-2007, 11:50 AM
I have acctually had luck with sanding the cerakote before you bake it. Sand it with 400 grit wet/dry, then applied another coat. Then, polishing by had, it came out real nice. The reason I sanded it, was because I had a run. And the spot that I sanded and resprayed, was twice as shiny. Just something to play with.
Dan Pesonen
Personal motto:
Cerakote burning/flaking off?? Banditperformance Powder Coating Questions 6 02-09-2007 01:33 PM
Unused Cerakote Chromex m67bd70x Used Items For Sale 2 07-25-2006 08:03 PM
caswell cerakote jtagger19 Powder Coating Questions 19 03-06-2005 06:24 PM
Cerakote Exotic Color Coatings engineerscott Powder Coating Questions 4 11-28-2004 09:09 AM
