Old 07-18-2007, 12:09 PM
gudgean is on a distinguished road
Default burn off
i built my oven to reach 700 degrees.what temp would i need to bring up a part for full burn off of two layers of powder?
Old 07-18-2007, 01:09 PM
FiReBReTHa is on a distinguished road
Send a message via AIM to FiReBReTHa
Default Re: burn off
to those asking about stripping powdercoat
Powdercoat... the other, other, multicolored meat.
Old 07-18-2007, 08:55 PM
cdaeme's Avatar
cdaeme is an unknown quantity at this point
Send a message via AIM to cdaeme Send a message via Yahoo to cdaeme
I had to get mine up to 900 just to start burning off two layers of powder. But be prepared it creates a lot of smoke.
Jason
Old 07-18-2007, 10:04 PM
I am still learning about removing.
but is it better to burn it off rather than use a good stripper?
Old 07-18-2007, 11:55 PM
JTW37's Avatar
Caswell Platinum Member
I just did a piece yesterday, that didn't turn out like I wanted, so this morning I used Permatex Gasket Stripper and it cut through three coats pretty fast. had to do a second application, but it didn't take very long for it to work. Rather do it that way as opposed to burning off.
Old 07-19-2007, 10:14 AM
i put it in the oven and turned it up and leterip.
i built the thing with recycled materials (old kitchen oven guts)and the temp dial is thermostat with contact built in.wired through a 6o amp contactor to power the elements.
so i turned it up passed the 600 degree mark.ive tested it with a multi meter that registers temp before and got 700 degrees. this time i just turned her up.
after about an hr at that high temp.the powder started to bubble up in places.and the smoke coming off it was heavy.
after about three /four hrs the smoke stopped and the pc was burned to a crisp.
most came off with a wire brush.the rest came off with a wire wheel on my buffer motor.
it may have cost me some in electricity but the effort and aggravation was greatly reduced and no stripper mess to deal with
granted i really dont know how hot it was .i just know IT WORKED!!!
  #8 (permalink)
Old 07-19-2007, 02:26 PM
cdaeme's Avatar
If I have just a few pieces that need burned off I use my torches to burn it off with a light flame. I works pretty quick and a lot less smoke. Just be careful on aluminum and dont focus on any one spot too long keep moving and come back if necessary.
Jason
Burn off temps jacob2025 Powder Coating Questions 5 02-21-2006 08:21 PM
high temp- how high? - will it burn? mtnbiker Powder Coating Questions 6 09-26-2005 11:47 PM
