FREE POWDER COATING SYSTEM
hey guys i have never used this Hi-Temp Lab metal $hit before and it is cracking after i take it out of my oven to sand it... WHY
![]() This is how i did it: 1) Sand blast piece blow off dust and wipe with solvent. 2) Fill with Lab metal and let air dry for 24 hours. 3) Put it in the oven for 1 hour at a little under 200 degrees celcius. 4) Removed from oven and Sanded lab metal and refill with lab metal. And let air dry for 24 hours. 5) Put it in the oven for 1 hour at a little under 200 degrees celcius. 6) Removed to sand it and it has CRACKED Too expensive $hit for this too happen. |
Ya, my l;uck with Lab Metal isn't good either. I have been in contact with the manufacturer and they say that no oven time before acctual baking. Even after cured for 24 hrs. Basically, spread, wait 24 hrs, sand and spread more. I just redid a Lab metal project with JB weld. And It takes about the same time to cure, 15 hrs for full cure. But it's working time is alot longer than Lab Metal. Meaning, you have more time to get it smooth so you have to sand less. JB weld is also tougher to sand than Lab Metal. So, smooth it out nicely before it cures=less work after
Dan Pesonen Bandit Powder Coat <<From Powder to Perfection>> Forest Grove, BC Canada Personal motto: "If it ain't broke, modify somethin till it is" |
JB has been my friend for years.
if you are in a hurry you can dry JB weld in the oven I do for 10-15 mins at powder cure temp. don't make it thicker than 1/8 or it will crack. |
so you can coat jbweld?? if yes, another yeason to love jb weld.
Powdercoat... the other, other, multicolored meat. |
Anybody tried this yet? http://www.thermobond3.com/ I won a free sample last month,haven't had a chance to try it!
Jason |
I brought lab metal and i was hopeing to use it as a filler similar to builders bog, but the $hit is watery as and it takes to long to build up thickness. I'm trying to find something that i can used to fill large dents and the likes. And i don't wanna have to wait two days before i can coat over it. In another forum some body mentioned a two part epoxy filler that can go up to 750 degrees. any body know what it is
Tiger Drylac has an epoxy repair kit. I've never used it, but it may be more workable than lab Metal. Can only be applied up to 2 mm thickness.
http://www.tigerdrylac.com/fileadmin...Repair_Kit.pdf Last edited by Harleydad; 07-30-2007 at 07:12 AM. |
| Since you asked....Lab Metal vs. PitStop ?? | dwoodruff | Electroplating Questions | 6 | 09-18-2007 06:48 PM |
| Spreading Lab Metal | Banditperformance | Powder Coating Questions | 14 | 08-30-2007 01:08 AM |
| Question about lab metal filler | norurb | Powder Coating Questions | 11 | 07-29-2007 05:10 PM |
| Let's talk about Lab Metal | Livinincolor | Powder Coating Questions | 6 | 10-03-2006 08:30 AM |
