FREE POWDER COATING SYSTEM
Is the new caswell gun any good? How much powder do you have to have in the cup for it to get it out. It looks like you have to have a full cup to do it. Im just a beginner but will be doing it alot. Any other guns you recomend?
thanks |
Full cup, Heck NO. I put about 7 heaping spoonfulls into the cup, and have good results. To much powder and it wil Burp and Clump out of the gun, not a fine powder cloud.
Dan Pesonen Bandit Powder Coat <<From Powder to Perfection>> Forest Grove, BC Canada Personal motto: "If it ain't broke, modify somethin till it is" |
depends on your budget. if you can afford it get a Gema.
SouthWest Powderworx Tyler Nutter 5054803934 www.swpowder.com myspace/swpowder tyler@swpowder.com |
I have a gun now like the Caswell $100 unit. I like mine so far.
I think I been using 1-2" of powder in the cup, not allot but not paying much attention to it, I just dump in a bit and go. I been doing 10"dia. flat plate steel parts so far, nothing fancy for me yet. |
The Caswell adjustable KV gun has been very good for me. At the start I thought there were a lot of problems with it, but it turns out I just didn’t know how to use it. You need to play around with the gun (different air setting, flow settings and gun to part distance.) Everyone sprays a little different. A few things to make sure of
1. Ware a respirator 2. Always filter the air to the gun 3. Never fill the cup up to much 4. Check your grounding with a meter (some people don’t realize you can't put the grounding clip over paint, it has to bet touching the metal.) 5. Outgas Outgas, Outgas . I am by far no pro but these are the things I have learned. Hope that this info helps |
![]() Anyone have or could make a video clip of doing PC? That I think would be very cool and help a lot of noobs. When I used the gun to do 6 small pieces, there was about 1/2 of the cup on the floor. I had a lot of over spray and would not stick. |
http://forum.eastwoodco.com/showthread.php?t=5941 Outgassing is used on cast materials such as aluminum,zinc,etc......along with things like car parts that have been subject to grease and oil. What you do is clean and degrease the parts. Put them in the oven to outgas @ about 50 degrees above the cure temp of the powder you are using and cook them for about an hour. What it's doing is opening the pores of the material to release any trapped air, junk, that in it. Blast after outgassing. As far as powder not sticking, are you sure you have a good ground? Last edited by Harleydad; 08-11-2007 at 11:07 AM. |
| Looking for a good cheap gun | 4birdman | Powder Coating Questions | 18 | 05-09-2007 06:34 PM |
| ew hobbie gun vs caswell hobbie gun | iwannapowdercoat2 | Powder Coating Questions | 16 | 01-12-2007 01:33 PM |
| want educated on caswells new gun | skooterbum | Powder Coating Questions | 7 | 09-14-2006 08:52 PM |
| Hey another question! Powder Gun acting weird | cruizer | Powder Coating Questions | 3 | 10-06-2005 05:11 PM |
