Old 07-30-2007, 04:19 PM
zoeconner is on a distinguished road
Default How do you coat this?
I want to do a bunch of 1 1/2" x 2 1/2" square pieces of 14 ga. on both sides. How do you do that? There is always going to be a side laying down. Wont that screw up the paint?
Old 07-30-2007, 07:18 PM
Default Re: How do you coat this?
Either drill a hole in it and hang by wire, or an aligator clip style?? There is allways going to be some part not coated. I almost allways hang my pieces. On some things I have had luck spraying the backside, baking, then flipping and spraying the front. A little less noticable rack marks, but they will still be there
Dan Pesonen
Forest Grove, BC Canada
Personal motto:
Old 07-30-2007, 09:10 PM
nuttyman's Avatar
nuttyman
yup-small hole & hang 'em.
SouthWest Powderworx
Tyler Nutter
5054803934
www.swpowder.com
myspace/swpowder
tyler@swpowder.com
Old 07-30-2007, 10:06 PM
I cant drill holes in them.
Old 07-30-2007, 11:28 PM
hp246 is on a distinguished road
Are they hollow so you can make a wire piece to fit through the hollow portion to hang the piece?
Old 07-31-2007, 12:20 AM
no solid piece of steel
Old 07-31-2007, 08:45 AM
zoeconner,
Solder/weld a wire to it, powder coat it, cut/grind the wire off. Touch it up and its a done deal.
John
  #8 (permalink)
Old 07-31-2007, 09:19 AM
chromo
Something that small and light weight I would try the aligator clip that was suggested. If your careful you could try cliping the part and coating it, use a second clip where already coated and coat where the first clip was the first time. I am guessing there will be minor teeth marks where the part was clipped but hopefully very minor.
  #9 (permalink)
Old 07-31-2007, 09:27 AM
This might be dumb but could you use a big magnet?
  #10 (permalink)
Old 07-31-2007, 10:10 AM
chromo
No, I don't think so for several reasons.
A magnet will probably be ruined if you bake it at 400F, most magnets lose their charge somewhere maybe 200-300F I think. I used to know some of the different type and temps but forgot now. Anyway you'll still need a hanger for baking!
Other problem I am pretty sure of is the poles of the magnet will ruin your coating job anyway. Since you need a negative charge on the part and the powder is a positive charge comming out of the gun the powder sticks to the part. So what happens if you stick a magnet to the part? The positive pole of the magnet will probably blow away the positive powder being sprayed at the part.
Likes repell.
Other thought is the negative pole of the magnet may suck up all the powder that might make it to the part, opposites attract, and the pole of the magnet is probably stronger than the part.
Another thought is surface area. A magnet stuck to a part will be worse than a little clip for the uncoated hanger area defect.
As I mentioned heat ruins magnets, you also won't be able to remove or move the magnet once part is coated with all that loose dust without ruining the coating on the part so you would end up having to bake the magnet with the part rather you want to or not.
I did give this a little thought already before if your wondering. I have some VERY strong NEO magnets, can barely seperate them by hand and an accident with them could break a finger, not cheap toys! I have smaller strong ones also.
I do allot with magnets and some parts I want to powder coat use these magnets. What I've decided is I will have to mask off the area where the magnets are bonded to the part and powder coat first, then bond the magnets to the parts. This means I have a stack of parts that will not get coated cause the magnets are bonded on already
Powder Coat Primer with Wet Paint Top Coat? FigureLLC Powder Coating Questions 10 07-02-2008 08:25 AM
Extreme Chrome with Clear Coat How to... hvac36 Powder Coating Questions 47 02-06-2008 09:57 PM
more than one coat bjmill81 Powder Coating Questions 2 03-28-2007 10:32 PM
Two Tone Powder Coat engineerscott Powder Coating Questions 5 03-27-2006 11:44 AM
2nd coat problems Austin_Dan Powder Coating Questions 4 12-02-2004 05:55 PM
