I am trying the Caswell black texture and find the instructions not very helpful. It says 10 minutes at 390deg then add .004 more. Then what? Any one use this stuff before and have more info to help. I am not getting a consistant product. Aby help would be appriciated...........
I am doing some motorcycle pegs and they are small parts but I am on my 3rd and fourth time doing this and it's starting to become frustrating. I have not made the call because I am the type to not cry wolf so soon but I think a call will be in order to see what I am doing wrong and for sure I will post it. Thanks for the responds..........
for texture colors
part MUST be super cleaned with not one single spot or it will not wrinkle on that spot as for 10 mins i think that is way to little time i'll gave it 20-25 first 10 minutes part might still be a gloss black and practically stating to wrinkle. |
I use Dupont Wrinkle black alot, and about the same is true. But the Dupont is 10 min @ 380, any longer and it sags. And definately the base prep needs to be consistent. One of my clients sandblasts, then sometimes hits the plasma torch slag area's with a sanding roll. Fine sanpaper roll, but the Wrinkle lays down totally different in the grinded area's.
Just did a job fro another client, a bunch of flat bar. It was sandblasted, but then handled without gloves. The metal sat for just over a week, and the fingerprint area's flash rusted a bit. You could see the fingerprints through the Wrinkle, and I laid a healthy coat on too. Moral, clean, clean clean, and Coat ASAP after cleaning/prepping
Dan Pesonen Bandit Powder Coat <<From Powder to Perfection>> Forest Grove, BC Canada Personal motto: "If it ain't broke, modify somethin till it is" |
Thanks guys for the suggestions and will put them to use. I also called Caswell for help and they gave me some direction. I am going to have some fun with this and let you know what I find...........
Just did another oven load of Wrinkle black, 150 Pcs, completely inconsistent. I am really getting ticked off at this powder. Before this, I did 200 SqFt of Jersy cream on aluminum panels, Smooth and even coverage. But the Wrinkle/texture stuff, is a PITFA
are you talking about a wrinkle or a fine texture ?
i use black fin texture from tiger a lot and i always get very good results finish is close to oem fine texture on hd parts . it is very consistant and covers small defects very well once parts reach about 385 i cure for another 15 minutes .works for me don t be afraid to over cure this powder ,i did overcure by 100 % and no problems but stay below the 400 degrees |
I am useing the "black wrinkle" from caswell. Thats the only black wrinkle that I seen on their list. I did not see a "fine texture" and looking at some pictures on the forum my results look more like the fine texture and not like the wrinkle that I am seeing. Sounds like another call to the tech people because I am cirtanly not getting the wrinkle finish that I am seeing that the rest of you are getting. Thanks for all the info guys I will keep everyone posted on my findings. Not willing to give up though, just not real happy with the results..........
Ya, I guess it's a Wrinkle. It's from Cloverdale paint acctually, Dupont made. My customer supplied 100 Lbs of it. He's a ongoing client, with 500+ pcs a month. The powder has a nice texture when applied 'just rigth', kinda sparkles in the sunlight. but a heavy coat, wrinkles.
| wrinkle black | baz | Powder Coating Questions | 9 | 08-14-2007 09:02 PM |
| Silver vein and Hig temp black questions | UnorthodoxCreations | Powder Coating Questions | 7 | 05-02-2006 12:07 AM |
| Marine application | Netnut | Powder Coating Questions | 12 | 08-09-2005 03:18 AM |
| Caswell burner black? | mtnbiker | Powder Coating Questions | 1 | 04-13-2005 12:15 PM |
| White Compound Turns Black? | GrillMan | Other Metal Finishing Questions | 2 | 08-23-2003 02:12 AM |
