Old 08-01-2007, 06:59 AM
donafams is on a distinguished road
Question Powder Coating Coil Springs?
Would powder coat crack on automotive front coil spring from the up and down movement?
If it can be coated, any ideas for hanging it, not any holes in them at all or flat surfaces to set them on?
Old 08-01-2007, 07:07 AM
Harleydad's Avatar
Default Re: Powder Coating Coil Springs?
Yes, they can be coated. As far as hanging, you could use the smallest wire possible and touch up the hook mark.
Old 08-01-2007, 07:10 AM
JTW37's Avatar
Caswell Platinum Member
Harleydad, what are you touching up with?
Old 08-01-2007, 08:47 AM
Harleydad's Avatar
This http://forum.eastwoodco.com/showthre...ght=hook+marks
Or there are companies that will mix a touch up paint to match your powder. You can get it in cans or pens. Most of the time I get the customer to drill some kind of hanging point.
I found sand blasting aluminum prior to powder coating is a big no-no. mtumbleson Powder Coating Questions 59 04-07-2008 07:37 PM
powder coating over powder coat? corybarta Powder Coating Questions 6 08-21-2006 08:15 AM
will powder coating work on shock springs, the flexing corybarta Powder Coating Questions 3 05-11-2005 05:58 PM
Non-paint powder coating dshepherd Powder Coating Questions 6 01-26-2004 11:49 AM
