Old 08-02-2007, 02:08 AM
outcastzeroone
Default Solar Flat Black issues
At work we tried useing some of hte caswell Solar Flat Black on a peice for a car we where working on. It had a couple of shiny spots on it and a booger so we sanded it down and reshot it with the flat and cooked it at 175 for 12 min. Only when we pulled it out it was gloss/semi gloss and not flat at all.
Has anyone had isues useing the Solar Flat Black before? Did we screw up on the second coat?
Old 08-02-2007, 03:53 AM
FigureLLC's Avatar
Caswell Platinum Member
Default Re: Solar Flat Black issues
solar flat black is noticibly more tempermental to apply than, say, super wet black when using a less expensive gun. double coating compounds this problem a lot. as far as it turning to semigloss, i haven't experienced that. were the lines clean? i've got to believe some kind of contamination is causing this. ...either from the gun, or on the part.
Len
Figure Engineering, LLC
Old 08-02-2007, 11:00 AM
Catchowder1 is on a distinguished road
The first powder my husband ever tried was solar flat black..to describe the powder as tempermental is an understatement. His research found that lots of other people have had trouble using the powder. It's an awesome color if you can get it to coat correctly.
My suggestion...just keep trying.
LyNsEy
Old 08-02-2007, 12:11 PM
FigureLLC's Avatar
also, if you need to touch up just a small spot, advance auto carries the small 1-2oz bottles of flat black automotive touch up paint. it'll be with the code-matched touch up paints. "universal flat black"
Len
Old 08-05-2007, 12:37 AM
UrineMachine is on a distinguished road
Isnt 175 an extremely low cure temp?
Old 08-05-2007, 02:30 AM
FigureLLC's Avatar
oh, yeah, i completely missed the 175 cure temp! i probably read it as 375. how heavy is the part you're coating. cure times (along with the corresponding cure temperatures) are based on when flow out (when powder first melts and looks glossy) begins. so if the cure schedule calls for 12min at 395, it'd take several minutes for flow out and THEN 12 more minutes. if you're coating a heavy steel part, it's gonna take more time to get it up to flow out temp. also, if some portions of the part are heavier than others, the flow out times are going to vary, and maybe this could be contributing to the uneven texture.
Len
Old 08-05-2007, 09:42 PM
Spitfire13 is on a distinguished road
Definitely undercured.
www.spitfirecustoms.com
Any trick to spraying flat powder? 4birdman Powder Coating Questions 3 03-07-2007 07:09 AM
Caswell high temp flat black looks lumpy in the sample pictu mtnbiker Powder Coating Questions 3 05-12-2005 06:26 PM
Flat black powder? wozzwinkl Powder Coating Questions 10 04-05-2005 12:37 AM
Questions about flat black melonaide Powder Coating Questions 0 02-28-2005 08:06 PM
