Old 08-02-2007, 05:27 AM
FigureLLC's Avatar
Caswell Platinum Member
Default Liquid Mask for Powder Coating
Does it exist?
Len
Figure Engineering, LLC
Old 08-13-2007, 08:33 PM
FigureLLC's Avatar
Default Re: Liquid Mask for Powder Coating
no? i feel like this should exist.
Len
Old 08-13-2007, 09:02 PM
Harleydad's Avatar
Yes, it does exist. Now I just to find a link.
Old 08-13-2007, 09:32 PM
Harleydad's Avatar
This is the stuff I saw. Does it work ? I don't know, never tried it.
http://www.hobbylinc.com/htm/div/div3020.htm
Old 08-14-2007, 10:16 AM
HD, I have that stuff, and use it for airbrushing. No, it will not withstand the heat of PC. When it dries, it's like a rubbery substance. Not to sure how hot it can withstand though. I should do some test panels one day.
Dan Pesonen
Forest Grove, BC Canada
Personal motto:
Old 08-14-2007, 06:44 PM
FigureLLC's Avatar
it'd be interesting for sure to see if it works.
i have a project i'll be working on in the near future that will require weld beads to be a different color than the members they join (the polished aluminum beads will not be coated), and i would expect trouble from the irregularity of the surface if i used a tape or adhesive type mask. at the moment, i think the wet sponge paint brush technique to remove the powder after application might be the best shot. i expect that to take much more time than applying a liquid mask, though.
Len
Old 08-14-2007, 08:36 PM
Harleydad's Avatar
Could you use it to mask, put the part in the oven until just before the powder starts to flow (a minute or two). Then pull it out to remove the mask and back in for full cure. (same thing that I do with the tape, you get a much cleaner line).
  #8 (permalink)
Old 08-14-2007, 10:06 PM
I have wondered that at times. I also do the "flow and de-tape" trick. Got to try it one day when I remember Damn old age LOL
Dan Pesonen
Personal motto:
  #9 (permalink)
Old 11-26-2007, 02:38 PM
FigureLLC's Avatar
ok, so i finally tried the liquid mask experiment last night. i used this stuff (i think):
results: total failure.
experiment 1: flow and demask. by the time the powder flowed out, the mask was liquified.
experiment 2: full cure and demask. the liquified mask outgassed so violently that it sputtered onto the clean sections, and it cured into the powder and adhered to the part.
on the bright side, for wet paint it did work well for masking some chrome that i couldn't find tape that would stick to. it took a long time to dry, like 24hr.
Len
  #10 (permalink)
Old 12-03-2007, 05:39 PM
FigureLLC's Avatar
bump. my update didn't ever show up, that i saw. i was thinking of trying rubber cement.
Len
I found sand blasting aluminum prior to powder coating is a big no-no. mtumbleson Powder Coating Questions 59 04-07-2008 08:37 PM
Fs: Turnkey Powder Coating And Ceramic Coating Business!!!! Mcurtis7 Used Items For Sale 0 10-02-2005 03:18 PM
Removal of unknown coating on aluminum rclint Metal Polishing Questions 6 08-25-2005 01:04 AM
Coating Brake Rotors rickanderson53 Other Metal Finishing Questions 4 08-19-2005 12:15 AM
Does a coating exist that can be bent slightly? Augest Powder Coating Questions 1 09-22-2003 02:34 PM
