Buy One Get One Free Powder Coatings
Until July 31st
BUY ONE POUND - GET ONE POUND FREE
(Same color only. Limit 1 Free Pound, Per Color, Per Customer)
- Enter 2 in the quantity field
- Pay the 1 Pound Price for 2 Pounds
Offer Valid On ALL powders, through 7/31, US Customers Only
ended up getting a 5 hp (22amp, 7.5hp peak), 80gal, 2 stage, 17.1 scfm @ 90, cast iron pump. it is the big kobalt from lowes. my research shows, as does the warranty info, that is is made by ABAC America (US made). it has an AO Smith motor but not sure who makes the pump. the specs state 82db, but i think it is louder than that, as the motor is 3450rpm and the pump states 1400rpm max (not sure of the exact rpm the pump is running at).
it was on clearance, as i believe lowes is not carrying that series anymore, so for $650, i could not pass it up. this was less than 1/2 the eaton i wanted, so i went for it. when i ran it, the pressure unloading check value wouldn't stop 'unloading'. when i called the service #, the call was answered by a PERSON and they were very helpful in giving me a cpl things to try. if that didn't work, they were going to send a new one. i did fix it, so didn't need a new one sent. i want to add a ball valve on the drain (or auto drain), extend the oil drain line and possibly route the air intake somewhere else, as that is where most of the noise comes from. from my research, the biggest problem w/ these units is the pressure line from tank to regulator is only plastic/nylon/vinyl and tends to not handle the temps of the compression process and blows. easy enough to fix...but i think i will wait until the warranty is up before i do too many mods. i haven't timed a complete fill up, but from kick on to kick off (140ish to 175ish), under no usage, is very short. |
I have a 10HP 120 gal. Eaton comp. I love it. good stuff those Eaton machines.
SouthWest Powderworx Tyler Nutter 5054803934 www.swpowder.com myspace/swpowder tyler@swpowder.com |
yeah I know. I paid $2500 total for mine.
| Tips and Tricks | non-stick | Powder Coating Questions | 27 | 11-11-2007 02:01 PM |
| newbie question to blasting | pklin | Other Metal Finishing Questions | 6 | 04-22-2007 03:50 PM |
| Sandblasting and prepping, newb help me! | emopunk96 | Powder Coating Questions | 15 | 04-18-2006 12:53 PM |
| Compressor help | mpierich | Metal Polishing Questions | 2 | 07-13-2005 10:29 AM |
| Compressor Amperage | edomingox | Powder Coating Questions | 2 | 04-12-2005 04:02 PM |
