Old 08-13-2007, 01:09 PM
UrineMachine is on a distinguished road
Default Xtreme chrome w/ super gloss clear a no go, again
Yesterday I tried to powdercoat a couple brackets extreme chrome with a super gloss clear coat - put the extreme in the oven @ 400F for all of about 12 mins pulled it out, sprayed the clear, put it in the oven for about another 15 - 20 mins, and it came out a very dulled gray. Last time I fully cured the extreme chrome for 30 mins this time I 1/2 cured it and sprayed the clear on right then. I dunno - I am not having much luck with the clear coat on this powder, which is unfortunate because the extreme chrome looks awesome pre-clear coat.
I redid it with just extreme chrome without clear to see how it holds up - it looks really good so far.
Old 08-14-2007, 10:18 AM
LittleViper's Avatar
LittleViper is on a distinguished road
Default Re: Xtreme chrome w/ super gloss clear a no go, again
I had a simular problem with clear. I had a orange and black piece that I shot clear on and the black turned green. I wanted to throw up!
Old 08-14-2007, 12:52 PM
Yeah exactly I dont know why it happens, either! These brackets will go on my other 5 series (they don't look bad, just not absolutely perfect) and I will re coat the others in just xtreme chrome with no clear. I couldn't blast the clear/chrome off on the first set.
Old 08-14-2007, 01:10 PM
Just use permatex gasket remover. Takes powder coat right off!
Old 08-14-2007, 07:30 PM
Harleydad's Avatar
Unfortunatly, thats the way it is with the chromes and clear.
Try (on a test piece) applying the extreme chrome and fully cure. Let it cool to room temp, then apply the clear (don't pre-heat the part). Compare it to what you just did and see if the results are better.
Old 08-19-2007, 12:38 AM
callmej75 is on a distinguished road
Send a message via Yahoo to callmej75
I just had the same problems. I have shot it many times without any problems before. I just ordered a one stage chrome so it doesn't need the clear coat.
Old 08-22-2007, 09:17 AM
JTW37's Avatar
Caswell Platinum Member
If you have your heart set on using Extreme, check the Sticky at the very top. I followed it and it came out better then the gray finish.
  #8 (permalink)
Old 08-22-2007, 07:26 PM
Harleydad's Avatar
My bad, I guess those instructions do say to pre-heat before applying the clear.
  #9 (permalink)
Old 08-23-2007, 10:00 AM
I am just going to pick up a 1 stage from another company
  #10 (permalink)
Old 08-23-2007, 02:26 PM
I sprayed a one stage yesterday and it looked just like the 2 stage when it didn't gray on me.
How thick for Super High gloss over Xtreme Chrome? UrineMachine Powder Coating Questions 2 03-04-2007 08:38 AM
Differences between HSFD and Super High Gloss Clear autoshopowner Powder Coating Questions 2 01-28-2007 08:49 PM
HFSD vrs. Super High Gloss Clear? mtnbiker Powder Coating Questions 3 09-08-2006 09:49 PM
Differences between HFSD Clear and Super High Gloss Clear sab0276 Powder Coating Questions 2 01-05-2006 03:08 PM
Super mirror 500+ gloss rated colors customandsound Caswell Please Sell This... 5 11-10-2005 08:20 PM
