Old 08-25-2007, 08:52 PM
donafams is on a distinguished road
Default Taping off Lettering?
i read the Eastood forum post of a guy that did valve cover lettering by covering the letters with green paitners tape and cutting out the letters.
I tried this and its hard.. Hard to see the edges of the letters and takes along time... anyone know a better way to do this?
have a few valve covers that i need seperate color on the letters
Old 08-26-2007, 12:49 AM
Harleydad's Avatar
Default Re: Taping off Lettering?
Pc the whole valve cover the color you want the letters to be and 1/2 to 3/4 cure. Pc the second color and using a damp finger or the cheap foam paint sponges remove the powder from the letters an full cure.
I'd post a pic for you ,but this site sucks arse to post pics on. Shoot me an e-mail at harleydad@new.rr.com and put "2 color valve cover" in the subject line. I'll reply and attach a pic.
Old 08-26-2007, 03:25 AM
Blazin_Jason is an unknown quantity at this point
Coated white, gelled, coated blue, removed the blue with q-tips, cured. It took a long time to clean up the lettering. I don't think it was the best way to do it, but it worked.
Old 08-26-2007, 07:10 AM
what is "gelled" ? and did you coat the whole piece white?
Old 08-26-2007, 03:25 PM
Ya I coated the whole thing white. Basically I put it in the oven long enough for the powder to flow out. You don't want to leave it in there too long.
Old 08-26-2007, 04:02 PM
so you sprayed blue over all that uncured white?.. wasnt it kind of rough over the lettering? i would think if it fully cured the lettering would be smooth and easier to wipe the blue off ?? am i off base here?
Old 08-26-2007, 04:28 PM
nuttyman's Avatar
nuttyman
yes, you're offbase! you don't have to fully cure the base, in this case the white. as said spray the white then let flow out for a few mins. pull the part & cool enough to handle without yelps escaping your maw. then spray the blue & using your favorite method remove the blue from the lettering & then fully cure.
SouthWest Powderworx
Tyler Nutter
5054803934
www.swpowder.com
myspace/swpowder
tyler@swpowder.com
  #8 (permalink)
Old 08-26-2007, 04:40 PM
what if you tape around the whole word... spray white, then clean up between the letters with a q-tip, fully cure.. then spray blue and clean off letters and bake?
  #9 (permalink)
Old 08-26-2007, 07:17 PM
Harleydad's Avatar
Twice as much work and you may burn the white.
  #10 (permalink)
Old 08-26-2007, 08:01 PM
burn the white?
in that eastwood post he fully cured the letters before spraying the rest of the cover and it didnt burn then letters
Help with taping LNZcustoms Powder Coating Questions 7 03-18-2007 10:59 PM
better taping way boston_jake01 Powder Coating Questions 8 01-27-2007 04:50 PM
Cleaning/polishing help with lettering on rim bob_fickel Metal Polishing Questions 5 06-29-2006 11:36 AM
Lettering on a valve cover??? 3000gtvr4 Powder Coating Questions 1 12-02-2005 09:04 AM
Help-Lettering my golf club y2khardtop Powder Coating Questions 4 05-13-2004 09:57 PM
