Go Back   Caswell Inc. Metal Finishing Forums > Powder Coating Questions
Connect with Facebook
Closed Thread
Old 08-27-2007, 02:04 PM
tjazcustoms is on a distinguished road
Default Help with handling/grounding candy topcoat
Yesterday I coated a small bracket with xtreme chrome and it looked great but the flamboyant blue topcoat didn't adhere that well. My question is how am I supposed to get a good ground after the chrome is applied. I clamped the clip to the chrome but the blue stayed real powdery and came off in spots when I transported to the oven. Thanks for any help!. This site is awesome!
Old 08-27-2007, 02:54 PM
Default Re: Help with handling/grounding candy topcoat
Shoot candy Hot fro best results. Part at just below200*F
Dan Pesonen
Forest Grove, BC Canada
Personal motto:
Old 08-27-2007, 06:11 PM
palmbeach's Avatar
palmbeach is an unknown quantity at this point
You can not get any grounding if you attach the grounding clip over top of the base coat. The grounding clip must make contact to the bare steel of the part you are coating. To have good grounding for the seconded coat you may need to file or sand away a small area of the base coat for the grounding clip to attach to. If you are ever unsure you have good grounding you can use a regular multimeter to double check it. hope this info help
Old 08-27-2007, 08:40 PM
Just use the same spot as you did for the base coat. I hand my parts with wire, so the wire does not come off untill they are done, that way it allwys is grounded to the same spot for all coats
Dan Pesonen
Personal motto:
Closed Thread
grounding problem,please help. quads Oven Building Forum 0 02-04-2006 09:55 AM
grounding? toxicd Powder Coating Questions 18 03-08-2005 12:07 AM
Grounding pdeinc Powder Coating Questions 11 09-01-2004 09:53 AM
Silvachrome topcoat Laquor or acrylic?? pierobello Other Metal Finishing Questions 0 09-05-2003 06:28 AM
Silvachrome Topcoat Question Therber Other Metal Finishing Questions 0 07-07-2003 04:48 AM
