Go Back   Caswell Inc. Metal Finishing Forums > Powder Coating Questions
Connect with Facebook
Closed Thread
Old 08-28-2007, 12:17 AM
chromo
Default Rust inside valve cover, What to do?
I am stripping a car to haul in for scrap iron, of course I am keeping some parts to Powder coat and use or sell.
I pulled the valve covers from this junker engine, 1984 3.8 Ford V6 and found rust inside the covers (even the rocker arms have some rust). Mostly just surface rust spots nothing to bad. This is also a cover with a spot welded baffle inside I think, I did not see any way to remove it yet.
For now the grease is soaking off the covers over night in simple green. I was going to try a stripper on the paint outside the cover and leave the inside as factory untill I found the rust and other plain steel with no coating inside.
What would you guys do with these? They're nothing special really, I was doing them more for practice than anything, but if they turn out nice enough I may put them on my 87 Cougar with same engine, so I want to do them right.
Old 08-28-2007, 01:11 AM
Default Re: Rust inside valve cover, What to do?
Clean the insides the best you can, scrub with wire brush to remove the main scale and coat them. Have run some pretty bad looking valve covers in my day, no worries
Dan Pesonen
Forest Grove, BC Canada
Personal motto:
Old 08-29-2007, 10:00 PM
BottleFed70 is on a distinguished road
Depends how much you want the valve covers I guess.
I'd sandblast them if worth the effort, or toss them...
Old 09-01-2007, 02:43 AM
chromo
Thanks.
I wasn't sure what others would do. I'll blast them out when I get my cabinet done then.
Closed Thread
Serious Help Needed, Polishing aluminum valve cover. m3the01 Metal Polishing Questions 29 01-28-2008 12:57 PM
Aluminum Valve Cover Question ptim Metal Polishing Questions 44 03-23-2007 05:32 PM
Lettering on a valve cover??? 3000gtvr4 Powder Coating Questions 1 12-02-2005 10:04 AM
valve covers millerperformance Powder Coating Questions 1 02-12-2005 02:08 PM
Valve cover and Strut Brace Problem Mr. Lee Metal Polishing Questions 10 08-29-2002 12:08 AM
