Old 09-08-2007, 10:29 AM
donafams is on a distinguished road
Question ClearCoat ?
should the base coat be fully cured before applying clearcoat?
Old 09-08-2007, 11:12 AM
holeshot87
Smile Re: ClearCoat ?
if u r using a chrome powder u have to fully cure. hope this helps
Old 09-08-2007, 12:32 PM
Default Re: ClearCoat ?
No chrome is best using a half bake I have found. You need to clear coat chrome ASAP after flow out to retain it's max shine. The best results I have had with clear or candies over chrome is I bake chrome a few min after flow out, then remove from oven, cool a little to 175F or less, then shoot, bake clear. This covers and seals the aluminum particles in the chrome poowder before they have ozidixed and lost their shine. That said, regular powders do not need to be hot, and I havnt noticed any benifit shooting regular colors hot because the base coat will soften when it heats up and the clear will meld into the base for good adhesion.
Dan Pesonen
Forest Grove, BC Canada
Personal motto:
Old 09-08-2007, 12:42 PM
so what if i did a valve cover with chrome letters and a black body, when would i shoot clear?
Old 09-08-2007, 09:43 PM
Personally, I'd do chrome first, bake 10 min at temp, then let cool, mask letters, spray black, bake anohter 10 or so till the black is flowed out, then remove the masking, spray clear.
Dan Pesonen
Personal motto:
Old 09-09-2007, 08:13 AM
thats basically what i did except for masking the letters, to much trouble, it was easier just wiping the black powder of them...
Clearcoat is cracking..... Wkillgs Powder Coating Questions 10 01-18-2008 09:50 PM
Clearcoat question donafams Powder Coating Questions 1 08-02-2007 08:17 PM
cracked clearcoat goldmankc Metal Polishing Questions 8 07-04-2007 11:42 PM
clearcoat mtlplshr Metal Polishing Questions 1 02-08-2002 09:41 AM
Clearcoat Chopper Doc Metal Polishing Questions 1 01-27-2002 09:53 PM
