Buy One Get One Free Powder Coatings
Until July 31st
BUY ONE POUND - GET ONE POUND FREE
(Same color only. Limit 1 Free Pound, Per Color, Per Customer)
- Enter 2 in the quantity field
- Pay the 1 Pound Price for 2 Pounds
Offer Valid On ALL powders, through 7/31, US Customers Only
View Powders Now
Old 09-11-2007, 10:02 PM
Daytony
Default Found My PC Technique Problem Now What?
I've done "some" powdercoating with my caswell powdercoating gun, I always seem to get a wavey/fish eye kind of apperance. Doesnt look bad but I wanted to improve my technique and get some do's and don'ts from you professionals.
This is how I used to powdercoat.
1. Sandblast the part(s) with FINE glass beads.
2. Wipe with tack cloth really well
3. Shoot PC
4. Bake.
My parts don't come out too bad this way but like I said it CAN improve and I think I've narrowed it down to my prep work (duh) lol
Anyways I see alot of clean after sandblasting with acetone, Is this an excellent way to get rid of nasty oils and contaminants?
Should I preheat the part's before final cleaning with acetone? This is where Im lost, I've never used acetone in my life.
Asking for help for a smooth mirror finish like powder is intended to. Thank's!
Tony M
Old 09-14-2007, 06:27 AM
donafams is on a distinguished road
Default Re: Found My PC Technique Problem Now What?
yes, clean with acetone
Old 09-18-2007, 01:50 AM
BottleFed70 is on a distinguished road
I keep hearing that the glass beads cause a lot of finish problems as the glass can become embedded in the part. Maybe try changing your blasting media?
Old 09-18-2007, 12:14 PM
baz baz is offline
baz will become famous soon enough
can you explain (i see a lot of clean after sandblasting with acetone)?
baz
http://www.polissagepb.com
Old 09-18-2007, 05:14 PM
chromo
Yes, clean with acetone before powder coating, it removes finger oils etc... for a clean part.
Many recomend wiping with a clean lint free rag and acetone, some say they spray it on from a squirt bottle.
Run a propane torch over the part to burn off any lint from rags etc... and dries it, just a quick pass don't need to heat the part. Keep flames away from acetone and such, propane on the part should be fine, make sure well ventilated when using it and close and remove can before using an open flame in the area. I think acetone is very flamable.
Found an easy cheap power supply bpu699 Electroplating Questions 0 07-03-2007 01:03 PM
I found a great coating remover! ublinkd Powder Coating Questions 3 11-14-2006 09:31 AM
raised letter/object sanding technique clperformance Powder Coating Questions 13 11-07-2005 12:37 AM
I found out this weekend.... cruizer Powder Coating Questions 6 07-04-2005 10:26 AM
technique for florescent/day-glo/neon colors strongtower Powder Coating Questions 5 05-12-2004 08:27 AM
