Old 09-20-2007, 04:39 PM
caseywan is on a distinguished road
Default Default Powder coating an assembled transmission??
Would it be unwise to attempt to powder coat a fully assembled transmission (minus bellhousing and shifter)?? It would probably need to be media blasted, but I would completely seal off the input shaft/output shaft area and shifter handle.
Old 09-20-2007, 08:43 PM
Default Re: Default Powder coating an assembled transmission??
Seals and O rings will not handle the heat
Dan Pesonen
Forest Grove, BC Canada
Personal motto:
Powder Coating Spoke Rim Assembled? chcustom Powder Coating Questions 3 12-10-2006 11:53 AM
powder coating over powder coat? corybarta Powder Coating Questions 6 08-21-2006 09:15 AM
Fs: Turnkey Powder Coating And Ceramic Coating Business!!!! Mcurtis7 Used Items For Sale 0 10-02-2005 03:18 PM
transmission casing berndog Metal Polishing Questions 3 05-21-2005 10:35 AM
Polishing Block and Transmission NCRXSI Metal Polishing Questions 16 12-02-2003 05:40 PM
