+ Reply to Thread
Results 1 to 2 of 2
Thread: Powder coat question.
  1. #1
    Default Powder coat question.
    HI!
    I HAVE ONE QUESTION REGARDING POWDER COATING.
    when i powder coat a part do i need some type of primer to completey cover the part? and if so is is safe to wet sand the primer to a smooth finish?
    like when you paint a car.you fix any damage then primer,wet sand then paint.
    thanks for the help
    Share with Facebook
  2. #2
    Join Date
    Dec 2002
    Location
    Central New York
    Posts
    353
    Default no primer
    You don't use primer with powder usually, there are exceptions though.
    You can use a pretreatment to clean the surface and promote adhesion.
    The powder will hide minor blemishes, if it's really rough you can use special fillers made for powder coating. If the surface is really bad go with a textured powder and it will hide an amazing amount of defects but you are left with an even textured surface instead smooth.
    Share with Facebook
+ Reply to Thread
Thread Information
Users Browsing this Thread
  1. powder coating over powder coat?
    By corybarta in forum Powder Coating Questions
    Last Post: 08-21-2006, 08:15 AM
  2. Finding a place to powder coat
    By RCLSolutions in forum Powder Coating Questions
    Last Post: 05-04-2005, 09:42 PM
  3. Laser printer = Powder Coat Printer?
    By tbloss001 in forum Powder Coating Questions
    Last Post: 08-30-2004, 06:08 PM
  4. I'm a first time powder coater. I have a quick question
    By Silverlex02 in forum Powder Coating Questions
    Last Post: 09-14-2003, 03:59 PM
  5. Painting over a powder coat
    By chromo in forum Powder Coating Questions
    Last Post: 01-29-2003, 01:20 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
