Old 10-01-2007, 08:25 PM
caseywan is on a distinguished road
Default Powder coating an engine block questions
I'm getting ready coat a couple bare blocks and my main question is this... can I shoot the block then put it in the oven while it's cold and just heat the oven up with the block in it then wait 30 minutes or so once the oven reaches temp? Cause the way my oven is set up it would be very hard to get a block in there when the oven is up to temp without loosing all the heat or getting burned.
Also, what do you guys use to mask off big items like a block?? I was thinking I was just going to use aluminum foil to tape off the lifter, head, and oil pan areas.
Old 10-01-2007, 08:57 PM
Default Re: Powder coating an engine block questions
I do it cold all the time , but remember it takes a long time to reach temp (about 1 hour or more), remember you have to start cure time once the block has reach the temp not the oven ,so don't worry about opening the door it's the only way you will be able to messure the temp.
I use alluminum foil and green tape to mask .
Engine block precise Powder Coating Questions 0 07-28-2007 11:50 PM
Powder Coating an Engine block? UrineMachine Powder Coating Questions 1 02-25-2007 09:47 PM
Anyone done an engine block? BlindUmpire Powder Coating Questions 18 10-08-2005 08:59 PM
Powder Coating Engine Block and Heads falconx Powder Coating Questions 3 07-21-2005 12:08 AM
Ceramic Coating an Engine Block? thesound Powder Coating Questions 13 02-19-2005 07:37 PM
