Go Back   Caswell Inc. Metal Finishing Forums > Powder Coating Questions
Connect with Facebook
Closed Thread
Old 10-15-2007, 11:32 PM
jpmassey is on a distinguished road
Default What am I doing wrong?
I need some help, this is driving me nuts.
I am powder coating new sheetmetal and I can't get a chean finish. 99% of the surface looks great, and then there is a few blotches of bubbles. I am using caswell's super wet black.
My process:
-Sand with 80 grit (not removing the scale, just smoothing it out).
-Soak in acetone for a couple minutes, lightly wipe down with a soaked towel.
-Outgas for 20-30 mintues @ 450*
-Cool to under 200*
-Soak in iron phosphate for a few minutes. (Preheated to ~90*)
-Soak in distilled water for a few minutes
-Hang up
-Dry in oven
-Shoot at about 200*
-Heat up for about 10 mintues (monitor temp with gun)
-Cure at ~400* for 10 minutes
-Cool in oven for another 10 minutes
I use latex gloves for touching.
Whats wrong!!! I have to do alot of these by the end of the week.
Thanks for any help
Old 10-15-2007, 11:37 PM
Default Re: What am I doing wrong?
Old 10-16-2007, 12:44 AM
baz baz is offline
baz has a spectacular aura aboutbaz has a spectacular aura about
My process:
-Cool to under 200*
-Hang up
-Dry in oven
Thanks for any help
out gassing is usually not needed for steel, aluminium is a porous material thet s why it needs to outgas .
cleaning with acetone is ok but the towell could be a problem , it can leave small lint particles on the metal.
contaminated powder could be a problem
moisture in the air line or oil in the air line is a major source of problem
dust in the air or on you or your clothes could also be a source of problem
if you are sure they are bubbles and not dust i would bet on moisture or oil in the line
Old 10-16-2007, 01:13 AM
I am using a Motorgaurd air filter, and a coiled copper air cooler. I never have used oil in the lines. I figured the phosphate and water wash would take care of any towel dust particles. I have seen a couple feathers here and there, but they are around sharp edges, etc, not in the middle of a flat spot.
I'll use a different can of powder next batch.
I may be only shooting textered powder if this keeps up.
Old 10-16-2007, 02:35 AM
Try doing one without Phosphate or rinse steps. I rarely phosphate hre. But then most my work doesnt call for it.
Dan Pesonen
Forest Grove, BC Canada
Personal motto:
Old 10-16-2007, 08:55 AM
Harleydad's Avatar
Harleydad will become famous soon enoughHarleydad will become famous soon enough
After the Acetone blow the part off with clean dry air. After the water rinse blow off with clean dry air and run small propane torch over the part to help remove any rag lint or dust bunnies still remaining. Lint free rags (microfiber) may also help. I think I'm with bandit on the contaminated air.
Old 10-16-2007, 01:07 PM
corecoatings is an unknown quantity at this point
Smile Re: What am I doing wrong?
I would say to sand blast it back down where it is bubbling, feather it back with a dA or hand sand it, and re coat the virgin metal? I have done it and you can get away with it if you make sure you get your temp up and make the powder flow.
  #8 (permalink)
Old 10-16-2007, 06:59 PM
I used a different powder can, same result.
I'm going into damage control mode, I'm going to try the speckled black. Probably can't see the small imprevections then.
I had problems with the gun charging last night. I had to turn if off and on several times. Wasted a TON of powder.
  #9 (permalink)
Old 10-16-2007, 10:28 PM
baz baz is offline
oil could be coming from the compressor. try blowing air on a white piece of paper for a while and check if it gets wet or moist or if it has some oily spots on it .you can add another filter just before the gun to help .
using texture powder will only hide the problem . better to spend alittle tim to find and fix the problem then all your jobs will be better looking
  #10 (permalink)
Old 10-17-2007, 01:34 AM
chromo
I agree with BAZ. "better to spend alittle time to find and fix the problem then all your jobs will be better looking"
"I'm going into damage control mode, I'm going to try the speckled black. Probably can't see the small imprevections then."
If you gotta get this job done and you can do that perhaps you'll be ok, but it's the chicken SSTT way out maybe. If you take that approach for all your work though you will never be a PRO. When you have a problem you must track it down and kill it! Fix it now, if you don't then it will haunt you for ever.
Happy Halloween
Closed Thread
what went wrong? dewil Anodizing Questions 22 03-19-2007 02:17 AM
What am I doing wrong? LCC Metal Polishing Questions 5 03-14-2007 09:45 AM
Ok,what am I doing wrong mach1man Metal Polishing Questions 1 08-18-2004 08:31 PM
ok, what am i doing wrong?please help a man out? dgc187 Metal Polishing Questions 12 06-30-2004 06:41 PM
What am I doing wrong here PC101 Powder Coating Questions 3 06-29-2003 11:14 PM
