Old 10-19-2007, 08:10 AM
donafams is on a distinguished road
Question 2nd Coat Question
ive noticed that first coats go on very smooth, but if i missed a small spot, and decide to spray a 2nd coat its not as smooth as the first. first is almost like glass and the 2nd is a little rougher. is this normall with powder on top of powder or is there a trickto nicer 2nd coats?
Old 10-19-2007, 09:12 AM
Harleydad's Avatar
Default Re: 2nd Coat Question
Are you trying to just touch up the light spot or do you cover the whole part? Are you sanding between coats and are you spraying them hot (hot flock) or cold?
Do you have an adjustable kv gun?
Old 10-19-2007, 05:54 PM
50kv gun, respraying the whole piece, warm, like about 160deg, not sanding between spraying
Old 10-19-2007, 06:32 PM
nuttyman's Avatar
nuttyman
that happens with glossy powders. 2nd coat glossy's can be tough. if a 2nd is needed w/ a glossy powder let it cool, sand & apply over the whole thing.
SouthWest Powderworx
Tyler Nutter
5054803934
www.swpowder.com
myspace/swpowder
tyler@swpowder.com
Old 10-19-2007, 09:38 PM
Harleydad's Avatar
After the sanding I'd blow it off with clean,dry air.
Old 10-20-2007, 02:06 AM
bradnailer is on a distinguished road
sand with what grit?
Old 10-20-2007, 09:07 AM
Harleydad's Avatar
220 should work for ya.
  #8 (permalink)
Old 10-21-2007, 11:27 PM
Spitfire13 is on a distinguished road
It sounds like you could be having a transfer efficiency problem. The 2nd coat might be a little thin. A thin coat will give you a rougher, tight orange peel effect. Do you have a gage to check your cured powder thickness?
www.spitfirecustoms.com
  #9 (permalink)
Old 10-22-2007, 01:36 PM
nuttyman's Avatar
nuttyman
i'm assuming we're all not completely inept @ this whole thing.
Tyler Nutter
5054803934
www.swpowder.com
myspace/swpowder
tyler@swpowder.com
Powder Coat Primer with Wet Paint Top Coat? FigureLLC Powder Coating Questions 10 07-02-2008 09:25 AM
powder coat removal question eliasson Powder Coating Questions 29 04-20-2007 09:28 AM
VHT Clear Coat Question maico996 Other Metal Finishing Questions 2 11-09-2005 01:30 PM
Powder coat question. Josh I Powder Coating Questions 1 03-28-2003 10:35 PM
